v4.4.0
Features
Relay support (TS011)
This adds support for the Relay specification (TS011). In the Device Profile it is possible to configure the Relay and Relay capable end-device parameters. Under the Application view it is possible to assign devices to a Relay (required for filtering and exchanging the device list with the Relay).
Note: Please note that this requires a Relay and Relay capable end-device.
Improvements
Build changes
The build configuration has been updated to generate fully static binaries based on musl libc. This solves the issue where in some cases ChirpStack would not connect over TLS to a PostgreSQL database. (#156).
This also changes the Docker base image to alpine, reducing the Docker image size by ~ 50% compared to debian:buster-slim. Within the Dockerfile we now COPY the already compiled binaries, which also reduces the build time on release.
If you are compiling ChirpStack from source, please refer to the README.md in the source repository as some commands have changed.
IFTTT integration
Configuration has been added to configure the prefix of the event name and to send arbitrary JSON payloads instead of the 3 value payload.
Other improvements
- Add
lrwn_filterscrate for filtering LoRaWAN PHYPayloads. - Dependencies have been updated.
- Expose enabled device-class in API and integration event output. (#58)
Bugfixes
- Fix
netid_typemethodpanicin case of invalid DevAddr prefix type. - Fix missing device
searchfilter (API). - Fix incorrect config template key for
bind([backend_interface]). - Fix default
CN470Class-B ping-slot frequencies. - Fix using system CA certificates for TLS. (#204)
- Fix OTAA join-request MIC check and DevNonce validation order.
