v4.8.1
Features
Duty-cycle metrics
This release implements duty-cycle metrics for each gateway. Please note that this feature is (currently) only available for EU868 region and if the ChirpStack Concentratord is used (v4.4.0+).
Increase RX1 Delay in device-profile
This makes it possible to increase the RX1 delay for one or multiple devices through the device-profile. This can be useful when the latency between ChirpStack and the integration is too high to be able to enqueue a downlink for the same RX1 / RX2 receive-windows. Note that it does not allow setting a RX1 delay lower than the rx1_delay value configured in the ChirpStack configuration files.
Improvements
- Update internal dependencies.
- Document missing
recvTimecodec option. (#385) - Show error in UI if clipboard API is not available. (231)
- Show ChirpStack version in web-interface (if user is admin). (#73)
- Expose more verbose JavaScript codec error output. (#391)
- Align multicast Class-B ping-slot configuration. (#255)
- Remove generated API code from repository to reduce amount of changes in case of API changes.
- Add support for responding to
HomeNSReqAPI requests (Backend Interfaces).
Bugfixes
- Do not update gateway location when updated lat / lon / alt are all set to 0.
- Fix typo in auth error string. (#367)
- Add auto-coversion from SEC1 EC keys to PKCS#8. (#386)
- Fix drawer header z-index issue in web-interface. (#393)
- Auto-detect if MQTT (v5) broker supports shared-subscriptions. (#413)
- Fix stats interval calculations in case of DST changes (in which case some timestamps don’t exist). (#415)
- Fix loading auto-complete options in web-interface. (#334)
- Do not schedule Class-B / Class-C downlinks for disabled devices.
