This marks the first stable release of the Concentratord project. This component has been shipped with the ChirpStack Gateway OS since the beginning of this year and many improvements have been made since then. The aim of this component is to be an easier to configure alternative for the Semtech UDP Packet Forwarder.
Currently it supports:
Embedded calibration values per gateway model
ZeroMQ based API (used by the ChirpStack Gateway Bridge)
Channel re-configuration without restart (with the ChirpStack Gateway Bridge, channel configuration can be sent over MQTT)
I see over at https://www.chirpstack.io/concentratord/ you have announced
Pre-compiled binaries for other gateways will be provided soon.
Will that also include the ability to install on a Pi outside of the Gateway OS as I run a customised OS along with additional services also running on the Pi.
This is a great piece of work which I am looking forward to trying. I’m really interested to see the CPU load it places on a Pi as my trials with the Semtech SX1302 UDP packet forwarder have shown the CPU load is double that of the Semtech Sx1301 packet forwarder.
My first focus would be to create vendor specific .ipk packages, as then I can package these with pre-defined config variables, specific to each gateway.
However, obtaining Pi compatible binaries is already very easy:
make build-armv7hf-release
This should already do the job for you I believe That command is executed within a Docker Compose environment including the HAL libraries etc…
One note, if you are using a RAK shield, uncomment the following two lines:
