Global search on organizations, applications, devices and gateways.
Display live device events (the same data as publised over MQTT).
See also Event logging.
Improvements:
When creating an application, show a warning when no service-profile exists.
When creating a gateway, show a warning when no network-server has been associated.
When creating a device, show a warning when no device-profile exists.
Bugfixes:
Fix organization selector (which would sometimes show an empty value on select).
Fix user selector when assigning an user to an organization (which would sometimes show an empty value on select).
Upgrade notes:
Before upgrading, the PostgreSQL pg_trgm extension needs to be enabled.
Assuming the LoRa App Server database is configured as loraserver_as this
extension could be enabled using the commands below.
Start the PostgreSQL prompt as the postgres user:
sudo -u postgres psql
Within the PostgreSQL prompt, enter the following queries:
-- change to the LoRa App Server database
\c loraserver_as
-- enable the extension
create extension pg_trgm;
-- exit the prompt
\q
Excuse me to disturb you, I tried yesterday (Wed 4 April) to upgrade my LoRa Server to the last version (on a Debian 9 VM); but, since then, when I look into lora-app-server log, I see this line.
I just upgraded the loraserver packages and it resulted in a migration error of the lora-app-server:
level=fatal msg=“applying migrations error: pq: operator class "gin_trgm_ops" does not exist for access method "gin" handling 0027_global_search.sql”
here a little more log:
time=“2018-04-25T15:03:53+02:00” level=info msg=“starting LoRa App Server” docs=“https://docs.loraserver.io/” version=0.20.1
time=“2018-04-25T15:03:53+02:00” level=info msg=“connecting to postgresql”
time=“2018-04-25T15:03:53+02:00” level=info msg=“setup redis connection pool”
time=“2018-04-25T15:03:53+02:00” level=info msg=“handler/mqtt: TLS config is empty”
time=“2018-04-25T15:03:53+02:00” level=info msg=“handler/mqtt: connecting to mqtt broker” server=“ssl://xxx.xxxxx.xxx:8883”
time=“2018-04-25T15:03:53+02:00” level=info msg=“applying database migrations”
time=“2018-04-25T15:03:53+02:00” level=info msg=“handler/mqtt: connected to mqtt broker”
time=“2018-04-25T15:03:53+02:00” level=info msg=“handler/mqtt: subscribing to tx topic” qos=0 topic=application/+/node/+/tx
time=“2018-04-25T15:03:53+02:00” level=fatal msg=“applying migrations error: pq: operator class "gin_trgm_ops" does not exist for access method "gin" handling 0027_global_search.sql”
did anyone had the same issue and has fixed the error already?
