LoRa App Server v3.4.0-test.1
Features
IDs for correlation
This release implements per context unique IDs that are printed in the logs and are returned as header in API responses. This makes it easier to correlate log events.
Organization admin permissions
Next to the organization admin permission, this release makes it possible to also (instead of full organization admin permissions), make an user “device admin” or “gateway admin”.
Migrate gateway stats
This release migrates the gateway stats from LoRa Server into LoRa App Server. This also adds new configuration options to the configuration file, to configure the timezone for aggregation and metrics retention.
Gateway map
In the gateway list page, it is now possible to show a map showing all the gateways and their states.
Upgrading
This release requires LoRa Server v3.3.0 or later (which will forward the gateway stats to the Application Server API). After upgrading LoRa App Server and restarting it, it will run a migration to import existing stats from the LoRa Server database. Therefore make sure LoRa Server is up and running during the upgrade of LoRa App Server.
Testing
Debian
Use the testing channel instead of stable:
sudo echo "deb https://artifacts.loraserver.io/packages/3.x/deb testing main" | sudo tee /etc/apt/sources.list.d/loraserver.list
Docker
Use the loraserver/lora-app-server:3.4.0-test.1 image and tag (available shortly).
