I’ve just published a new release of all components! The two major changes:
- The configuration of all components has been refactored
- LoRa (App) Server now supports streaming frame-logging
LoRa Gateway Bridge
2.3.0
Features:
LoRa Gateway Bridge uses a new configuration file format.
See configuration for more information. -
Support MQTT client certificate authentication (#74).
Upgrade notes:
When upgrading using the .deb package / using apt or apt-get, your
configuration will be automatically migrated for you. In any other case,
please see configuration.
LoRa Server
0.24.0
Features:
- LoRa Server uses a new configuration file format.
StreamFrameLogsForGatewayAPI method has been added to stream frames for a given gateway MAC. -
StreamFrameLogsForDeviceAPI method has been added to stream frames for a given DevEUI. - Support MQTT client certificate authentication (#284).
Changes:
GetFrameLogsForDevEUIAPI method has been removed. Theframe_logtable
will be removed from the database in the next release!
Upgrade notes:
LoRa App Server
0.18.0
Features:
- LoRa App Server uses a new configuration file format.
See configuration for more information. - Frame-logs for device are now streaming and can be downloaded as JSON file.
Note: the
/api/devices/{devEUI}/frames(formerlyDevice.GetFrameLogs)
endpoint has changed (and the gRPC method has been renamed toDevice.StreamFrameLogs). - You need LoRa Server 0.24+ in order to use this feature.
Note: the
- Added streaming frame-logs for gateways (which also can be downloaded as JSON file).
- Support MQTT client certificate authentication (#201).
Upgrade notes:
