v3.2.0-test.1
Features
NetID and JoinEUI filters
Configuration options have been implemented to filter uplink messages on netID and JoinEUI. This makes it possible to ignore messages from neighboring to save on bandwidth usage (e.g. when the gateway is using a cellular backhaul).
Execute commands
This feature makes it possible to execute commands on the gateway (when the LoRa Gateway Bridge is running on the gateway). Note: commands must be pre-configured in the LoRa Gateway Bridge configuration file.
Testing
After installing the test-release, you can generate a new configuration file as documented: https://www.loraserver.io/lora-gateway-bridge/install/config/#configuration-file.
lora-gateway-bridge configfile --config lora-gateway-bridge-old.toml > lora-gateway-bridge-new.toml
Or:
/path/to/lora-gateway-bridge configfile --config lora-gateway-bridge-old.toml > lora-gateway-bridge-new.toml
This configuration file will contain examples and documentation with regards to the filters and command execution features.
Debian
Use the testing channel instead of stable:
sudo echo "deb https://artifacts.loraserver.io/packages/3.x/deb testing main" | sudo tee /etc/apt/sources.list.d/loraserver.list
Downloads (.tar.gz and .deb):
See the lora-gateway-bridge-3.2.0-test.1... packages: https://artifacts.loraserver.io/downloads/lora-gateway-bridge/.
Docker
Use the loraserver/lora-gateway-bridge:3.2.0-test.1 image and tag.
