These releases enable Class-B support in LoRa Server and LoRa App Server
(and some other features that will help you to keep your LoRaWAN network related settings in sync). Please use https://forum.loraserver.io/t/class-b-support-in-lora-server/939 for Class-B related discussions. Below are the change logs of both components.
LoRa Server
0.25.0
Features:
Class-B support! See Device classes
for more information on Class-B.- Class-B configuration can be found under the
network_server.network_settings.class_b
configuration section. -
Note: This requires LoRa Gateway Bridge
2.2.0 or up.
Extended support for extra channel configuration using the NewChannelReq mac-command.
This makes it possible to:- Configure up to 16 channels in total (if supported by the LoRaWAN region).
- Configure the min / max data-rate range for these extra channels.
Implement RXParamSetup mac-command. After a configuration file change,
LoRa Server will push the RX2 frequency, RX2 data-rate and RX1 data-rate
offset for activated devices. -
Implement RXTimingSetup mac-command. After a configuration file change,
LoRa Server will push the RX delay for activated devices.
LoRa App Server
0.18.1
Features:
- Expose Class-B fields in device-profile web-interface form.
- Note: Class-B support is implemented since LoRa Server 0.25.0.
Bugfixes:
- Fix factory preset frequency field in device-profile form.
