LoRa Server v.2.4.0
Upgrade notes
This update will migrate the gateway statistics to Redis, using the default *_aggregation_ttl
settings. In case you would like to use different durations, please update your configuration before upgrading.
Improvements
Gateway statistics
Gateway statistics are now stored in Redis. This makes the storage of statistics more lightweight and also allows for automatic expiration of statistics. Please refer to the [metrics.redis]
configuration section and the *_aggregation_ttl
configuration options.
Join-server DNS resolver (A record)
When enabled (resolve_join_eui
), LoRa Server will try to resolve the join-server using DNS. Note that currently only the A record has been implemented and that it is assumed that the join-server uses TLS. Experimental.
FPort > 224
LoRa Server no longer returns an error when a fPort
greater than 224
is used.
Bugfixes
- Fix init.d logrotate processing. (#364)
