LoRa Server v3.3.0
Features
IDs for correlation
This release implements per context unique IDs that are printed in the logs and are returned as header in API responses. This makes it easier to correlate log events.
Forwards gateway stats to Application Server API
This decouples the storage / handling of gateway stats from the Network Server. This deprecates the GetGatewayStats
API method (will be removed in the next major version).
Extend Network Controller API
Next to the already existing HandleUplinkMetaData
method, this adds a HandleDownlinkMetaData
API method. The HandleUplinkMetaData
API call has been extended with more meta-data (e.g. DevEUI, payload size, …) which can be used for accounting purposes.
Improvements
- Add PostgreSQL max open / idle connections settings. (#437)
Bugfixes
- Recover Azure Service-Bus queue client on Receive error.
- Fix unreturned errors. (#428)
- Fix send on closed channel. (#434)
- Fix logging DevEUI in join flow. (#438)
Upgrading
Although not required, to benefit fully from the IDs for correlation feature, it is recommended to update LoRa Gateway Bridge to v3.3.0 (or later).
As the gateway stats are now forwarded to the Application Server API, in order to continue receiving gateway stats you must upgrade to LoRa App Server v3.4.0 (or later).
