This release implements per context unique IDs that are printed in the logs and are returned as header in API responses. This makes it easier to correlate log events.
Forwards gateway stats to Application Server API
This decouples the storage / handling of gateway stats from the Network Server. This deprecates the GetGatewayStats API method (will be removed in the next major version).
Extend Network Controller API
Next to the already existing HandleUplinkMetaData method, this adds a HandleDownlinkMetaData API method. The HandleUplinkMetaData API call has been extended with more meta-data (e.g. DevEUI, payload size, …) which can be used for accounting purposes.
Although not required, to benefit fully from the IDs for correlation feature, it is recommended to update LoRa Gateway Bridge to v3.3.0 (or later).
As the gateway stats are now forwarded to the Application Server API, in order to continue receiving gateway stats you must upgrade to LoRa App Server v3.4.0 (or later).
Testing
Debian
Use the testing channel instead of stable:
sudo echo "deb https://artifacts.loraserver.io/packages/3.x/deb testing main" | sudo tee /etc/apt/sources.list.d/loraserver.list
Docker
Use the loraserver/loraserver:3.3.0-test.1 image and tag.
major version).
Improvements
Add PostgreSQL max open / idle connections settings. (#437)
Bugfixes
Recover Azure Service-Bus queue client on Receive error.
