Remote Progressql Database
Hello
I have a milesight UV300 that is polling RS485 modbus data, i would like to send and store this data into a remote prosgresql server to display the data in grafana
My chirpstack will be in the cloud, and my grafana/db server is on anoter instance
Would this be possible?
Yes, this is possible. change the configuration file to point it to your pgsql server.
I did this on my installation using docker-compose
Thank you for the reply!
Is this possible using the ubuntu version not using docker?
I think so…you just need to locate and edit this
# PostgreSQL DSN.
** # Format example: postgres://:@/?sslmode=.**
** # SSL mode options:**
** # * disable - no SSL**
** # * require - Always SSL (skip verification)**
** # * verify-ca - Always SSL (verify that the certificate presented by the server was signed by a trusted CA)**
** # * verify-full - Always SSL (verify that the certification presented by the server was signed by a trusted CA and the server host name matches the one in the certificate)**
dsn=“postgresql://chirpstack:chirpstack@ipaddressofyourserver/chirpstack?sslmode=disable”
