Reset command Bmeters
Good day,
Can someone please take me through how to reset one of my Bmeters(Water Meters) LoraWAN module using the network server.
According to documentation from Bmeters i should use the command “Starting value”
You should look at the device user guide/spec and see what value it wants sent. Then you can queue it (as hex if using the web UI).
I’m not sure I follow.
This is the email I received from them: To reset the volume you need to use the command “Starting value”
Should I convert the “Starting value” into hex and then publish it via GUI?
And if so what tool do you recommend for the conversion? (Will it be string to hex)
I don’t know anything about the device you’re referencing, but the manufacturer should be able to provide you (or on their web site) with a full guide that includes uplink and downlink payloads, and how to decode the values. That will explain what you need to send.
This is the device with documentation. If you could maybe assist me how this can be done in chirpstack. https://www.bmeters.com/wp-content/uploads/2021/06/Manual-RFM_LR1_1.1.2_ENG.pdf
0305 as the HEX value on port1?
Yes, that looks correct.
