Hi all,
I would like to report an issue I have with devices using RN2483A (FW: “RN2483 1.0.5 Oct 31 2018 15:06:52”) in combination with ChirpStack. I wonder if anybody has similar experiences or a solution to this issue?
Problem description:
Device-status request frequency = 4 (enabled):
- Device joins successfullly
- Sends uplink frame 0
- Receives downlink frame 0: LinkADRReq + DevStatusReq
- RN2483A hangs, no response to AT command anymore, hard reset needed.
Workaround:
Device-status request frequency = 0 (disabled):
- Device joins successfully
- Continues normally.
Additional observations:
- With Actility/Thingpark: The exact same device responds correctly to DevStatusReq. Actility sends DevStatusReq (without LinkADRReq) in downlink frame 0.
- With the older firmware “RN2483 1.0.4 Oct 12 2017 14:59:25”, the device responds correctly to DevStatusReq.
- Changing settings like LoRaWAN MAC version did not help. I use EU868, LoRaWAN 1.0.2 RevB normally.
Do you have similar experiences? Solutions other than disabling DevStatusReq?
Thanks a lot!
