I´m getting some issue requesting end device join by OTAA. My Lora-App-Server receives, process e and answer OK about the Join request but the end device doesnt receive this answer. At the device I can see a DENIED answer. Here the lora-app-server log:
I’m working with @pzuchinali to solve this problem. Here are some screenshots of the response received in the “Lora development utility” application and the response received on the NS “Live LoraWan Frames” page.
A common mistake is that in the Device-profile, LoRaWAN 1.1.0 is selected. This is not supported by most devices. For the RN2903 you must select 1.0.2.
Thank you @brocaar. We will for sure check this information. Regarding the logs and messages above, do you see anything wrong? As we are seeing that the Join is accepedted, it reaches the Kerlink Gateway but it is not received by the device.
