Rpc error: code = Unimplemented desc = unknown service ns.NetworkServer" grpc.code=Unimplemented grpc.method=CreateRoutingProfile grpc.service=ns.NetworkServer
I can’t create a Network-Server.
When starting services all is ok. loraserver.service, lora-gateway-bridge.service and lora-app-server.service.
But, we intend save the first network-server in localhost:8000 or 10.0.1.112:80000 or 0.0.0.0:8000, we receive this error.
All service are running in the same virtual machine, inner my local net.
INFO
root@eol-LoRaServer:/var/log# loraserver version 2.0.0
root@eol-LoRaServer:/var/log# lora-app-server version 1.0.2
root@eol-LoRaServer:/var/log# lora-gateway-bridge version 2.4.1
ago 07 13:07:52 eol-LoRaServer lora-app-server[3665]: time=“2018-08-07T13:07:52+02:00” level=warning msg=“creating insecure network-server client” server=“0.0.0.0:8000”
ago 07 13:07:52 eol-LoRaServer lora-app-server[3665]: time=“2018-08-07T13:07:52+02:00” level=error msg=“finished client unary call” error=“rpc error: code = Unimplemented desc = unknown service ns.NetworkServer” grpc.code=Unimplemented grpc.method=CreateRoutingProfile grpc.service=ns.NetworkServer grpc.time_ms=0.359 span.kind=client system=grpc
ago 07 13:07:52 eol-LoRaServer lora-app-server[3665]: time=“2018-08-07T13:07:52+02:00” level=error msg=“network-server create routing-profile api error” error=“rpc error: code = Unimplemented desc = unknown service ns.NetworkServer”
ago 07 13:07:52 eol-LoRaServer lora-app-server[3665]: time=“2018-08-07T13:07:52+02:00” level=error msg=“finished unary call with code Unknown” error=“rpc error: code = Unknown desc = rpc error: code = Unimplemented desc = unknown service ns.NetworkServer” grpc.code=Unknown grpc.method=Create grpc.service=api.NetworkServer grpc.start_time=“2018-08-07T13:07:52+02:00” grpc.time_ms=7.212 peer.address="[::1]:53384" span.kind=server system
I am also facing this issue.
Please see below log
time=“2018-09-14T10:17:03+05:30” level=error msg=“finished client unary call” error=“rpc error: code = Unimplemented desc = unknown service ns.NetworkServer” grpc.code=Unimplemented grpc.method=CreateRoutingProfile grpc.service=ns.NetworkServer grpc.time_ms=0.454 span.kind=client system=grpc
time=“2018-09-14T10:17:03+05:30” level=error msg=“network-server create routing-profile api error” error=“rpc error: code = Unimplemented desc = unknown service ns.NetworkServer”
time=“2018-09-14T10:17:03+05:30” level=error msg=“finished unary call with code Unknown” error=“rpc error: code = Unknown desc = rpc error: code = Unimplemented desc = unknown service ns.NetworkServer” grpc.code=Unknown grpc.method=Create grpc.service=api.NetworkServer grpc.start_time=“2018-09-14T10:17:03+05:30” grpc.time_ms=5.377 peer.address="[::1]:35926" span.kind=server system=grpc
Please help me…!
Easy, re-install the last version.
The (.deb) repositories have been modified the last weekend, and this new version solves this error.
@nettek
We already using last version of .deb repository
sudo echo “deb https://artifacts.loraserver.io/packages/2.x/deb stable main” | sudo tee /etc/apt/sources.list.d/loraserver.list
we are getting same error
Error rpc error: code = Unimplemented desc = unknown service ns.NetworkServer (code: 2)
I am sorry, we have two distinct servers, one with deb deployment, one with docker-compose deployment.
They’re working properly, after the last installation, this last monday.
Please, remove all previous installation, and re-install the new package.
And try create new network server.
I don’t know what is the correct way to deploy with deb repository, because I don’t maked this installation, this responsability is for another team.
This twuesday, I been created a new installation with docker utilities and this one is run fine.
