I have installed the lora gateway bridge in my kerlink, however it seems that it does not capture the packet forwarder messages.
I have installed this packet forwarder: https://www.thethingsnetwork.org/docs/gateways/kerlink/config.html (Semtech one)
when I run tcpdump -AUq port 1700
I can see packets coming in the gateway but I see no packets logs when I start the lora gateway program:
INFO[0000] starting LoRa Gateway Bridge docs="https://docs.loraserver.io/lora-gateway-bridge/" version=2.1.5
INFO[0000] backend: connecting to mqtt broker server="tcp://iot.eclipse.org:1883"
INFO[0000] gateway: starting gateway udp listener addr=0.0.0.0:1700
INFO[0000] backend: connected to mqtt broker
Any ideas how I can debug this? thanks!
