Sorry, Linux dummie here.
I want to migrate to Chirpstack V4 mainly because of the multi region support. So far I was running Chirpstack V3 with a single region.
Chirpstack is running on a Ubuntu 20.04.4 LTS installation running on a VPS. v3 works without any problems.
I already have two toml files for the two regions I want to use.
I was able to use the migration tool to go to V4 and it puts both regions in the new files.
But then, for multiple region support, it seems I need to run multiple instances of the Chirpstack Gateway Bridge:
But I have no idea how to do that. Can someone give me a hint how to start the gateway bridge in two instances, each using its own toml configuration?
Please note that the chirpstack-gateway-bridge
is a single binary, that you can execute multiple times. It takes a -c
argument for the configuration file. What you probably want to do is create multiple Systemd services, each per region.
See as an example:
https://github.com/chirpstack/chirpstack-gateway-bridge/blob/master/packaging/files/chirpstack-gateway-bridge.service. This file is copied to /lib/systemd/system/chirpstack-gateway-bridge.service
Maybe this could be helpful too: Systemd Essentials: Working with Services, Units, and the Journal | DigitalOcean.
@brocaar
Thanks, as I said, I am a linux dummy.
So I would change this line
ExecStart=/usr/bin/chirpstack-gateway-bridge
to include the -c xxxx.toml config file, correct?
@brocaar
Thanks a lot, now I have (still on old Chirpstack) two regions working.
I love Chirpstack!!!
