Hi everyone,
Yesterday I updated our chirpstack from version 4.5 to 4.8.1.
I noticed that the value of the “rxInfo[0].location.altitude” property is the same as the value of the longitude.
I was able to verify that the messages on the MQTT server have the correct location values.
Does anyone else have the same situation?
I haven’t yet tried building the system from source and debugging, but looking at line 87 in the below it seems like this could be a simple typo in the backend code.
use std::collections::hash_map::DefaultHasher;
use std::collections::HashMap;
use std::hash::{Hash, Hasher};
use std::str::FromStr;
use std::time::Duration;
use anyhow::{Context, Result};
use chrono::{DateTime, Local, Utc};
use tracing::{error, info, span, trace, warn, Instrument, Level};
use crate::gateway::backend as gateway_backend;
use crate::helpers::errors::PrintFullError;
use crate::storage::{error::Error, fields, gateway, metrics};
use crate::{config, region};
use chirpstack_api::{common, gw};
use lrwn::EUI64;
pub struct Stats {
gateway_id: EUI64,
stats: gw::GatewayStats,
This file has been truncated. show original
I’ll raise it as an issue so that it can be looked at, and hopefully corrected in a subsequent release.
Hey,
We upgraded to ChirpStack version 4.8.1 recently and have seen the same issue.
The gateway logs indicate it is sending the correct value so it does seem like a ChirpStack issue.
abaena
July 11, 2024, 10:55am
4
It is definitively a bug, as @matteogales says at the line 87 of the file he shared. Must be “altitude” and not “longitude”. Open a new Issue in the Chirpstack repo, as it’s a bug and needs to be solved.
This was kindly fixed this morning by offizium-berndstorath (Bernd Storath) · GitHub , with his pull request merged into the master branch by Orne.
opened 08:51PM - 10 Jul 24 UTC
closed 08:01AM - 11 Jul 24 UTC
As described in the below topic on the ChirpStack forum, there appears to be an … issue with the altitude being reported for gateways in version 4.8.1 of ChirpStack (I have not noticed this issue in previous versions).
https://forum.chirpstack.io/t/rxinfo-altitude/21467
I'm not sure if this is helpful (or indeed correct; apologies I have not built and debugged the code, but I am happy to test any potential fixes) this could be down to line 87 in the below file.
https://github.com/chirpstack/chirpstack/blob/v4.8.1/chirpstack/src/uplink/stats.rs
It was really great to see open source software development working in this really efficient manner.
system
Closed
October 9, 2024, 8:31pm
6
