Hi ,
I changed the configuration of network server and application server by following this guidelines.
https://www.chirpstack.io/network-server/install/config/
I generated a new configuration file by:
chirpstack-network-server configfile > chirpstack-network-server.toml
I modified the configuration file and saved. Then check with this command:
It shows that it is modified accordingly.
Then I restart the chirpstack-network-server:
sudo systemctl restart chirpstack-network-server
and check the log:
sudo journalctl -f -n 100 -u chirpstack-network-server
I found that the setting was not changed.
I also tried to reboot the system. The result was same.
My Question is:
- How can I save the configuration setting and activate it?
Thank you.
Regards,
Chapman
