Seeed S2100 codec v.3 needed
I have a Seeed S2100 Data Logger working on my RAK7244 chirpstack v.3 gateway. It doesn’t decode the payload. Is there a recent codec for this device? The one from the Seeed wiki does not seem to decode. Thanks.
bgrattan@umw.edu
If you share the decoder we may be able to help, typically it is just the function inputs, name and return that need changing.
Hi Liam,
Thanks for the reply and offer. Seeed just sent me an updated codec file for the S2100 which seems to work. It decodes my payload from V1 (analog voltage) correctly and lists it as “measurement” in the data output. I don’t see any way to attach the file here–if you are interested, I can email it to you.
Cheers,
Bob
Hello bgrattan, it’s possible to have to codec for S2100 for shirpstack server 4.4 because i difficult , i not solution for you.
I have SDC41 TEMPERATURE / HUMIDITI and CO2
christopher
thank you
Did you get it and was it helpful?
