is it possible to configure chirpstack to use RX2 with SF12 and 869.525 MHz for sending Join Accept message? Actually my chirpstack instance always sends on same datarate and frequency on RX1 window…
There are some options you can tweak:
# RX window (Class-A).
# Set this to:
# 0: RX1 / RX2
# 1: RX1 only
# 2: RX2 only
rx_window=0
# RX1 delay (1 - 15 seconds).
rx1_delay=1
# RX1 data-rate offset
rx1_dr_offset=0
# RX2 data-rate
rx2_dr=0
# RX2 frequency (Hz)
rx2_frequency=869525000
rx2_prefer_on_rx1_dr_lt=0
# Prefer RX2 on link budget.
https://www.chirpstack.io/docs/chirpstack/configuration.html#example-region_eu868toml-configuration
