Greetings, I m pretty much stuck here can anyone help?
journalctl -u lora-app-server -f -n 50
Sep 14 06:28:18 Beaglebone lora-app-server[2851]: time=“2018-09-14T06:28:18Z” level=info msg=“gateway ping created” dr=10 frequency=868100000 gateway_mac=e8eb11fffe254cf9 id=186657
Sep 14 06:28:18 Beaglebone lora-app-server[2851]: time=“2018-09-14T06:28:18Z” level=error msg=“finished client unary call” error=“rpc error: code = Unknown desc = lorawan/band: invalid data-rate” grpc.code=Unknown grpc.method=SendProprietaryPayload grpc.service=ns.NetworkServerService grpc.time_ms=9.534 span.kind=client system=grpc
Sep 14 06:28:18 Beaglebone lora-app-server[2851]: time=“2018-09-14T06:28:18Z” level=error msg=“send gateway ping error: send ping error: send proprietary payload error: rpc error: code = Unknown desc = lorawan/band: invalid data-rate”
journalctl -u loraserver -f -n 50
Sep 14 06:29:08 Beaglebone loraserver[2366]: time=“2018-09-14T06:29:08Z” level=error msg=“finished unary call with code Unknown” error=“rpc error: code = Unknown desc = lorawan/band: invalid data-rate” grpc.code=Unknown grpc.method=SendProprietaryPayload grpc.service=ns.NetworkServerService grpc.start_time=“2018-09-14T06:29:08Z” grpc.time_ms=0.229 peer.address=“192.168.7.2:57780” span.kind=server system=grpc
brocaar
September 16, 2018, 9:51am
2
I think the error is pretty clear. From the frequency I take that you’re using the EU868 band. You have configured dr=10 which is not valid for the EU868 band. Please refer to the LoRaWAN Regional Parameters specification for valid options.
Thanks for the reply @brocaar
I did go through the regional paaramaeters setting and fixed it now Im left with this:
journalctl -u lora-gateway-bridge -f -n 50
Sep 14 14:56:48 Beaglebone lora-gateway-bridge[2388]: time=“2018-09-14T14:56:48Z” level=debug msg=“gateway: received udp packet from gateway” addr=“127.0.0.1:36372” protocol_version=2 type=PullData
Sep 14 14:56:48 Beaglebone lora-gateway-bridge[2388]: time=“2018-09-14T14:56:48Z” level=debug msg=“gateway: sending udp packet to gateway” addr=“127.0.0.1:36372” protocol_version=2 type=PullACK
Sep 14 14:56:51 Beaglebone lora-gateway-bridge[2388]: time=“2018-09-14T14:56:51Z” level=debug msg=“gateway: received udp packet from gateway” addr=“127.0.0.1:60253” protocol_version=2 type=PushData
Sep 14 14:56:51 Beaglebone lora-gateway-bridge[2388]: time=“2018-09-14T14:56:51Z” level=info msg=“gateway: stat packet received” addr=“127.0.0.1:60253” mac=XXXXXXXXXXXXXX
Sep 14 14:56:51 Beaglebone lora-gateway-bridge[2388]: time=“2018-09-14T14:56:51Z” level=info msg=“backend: publishing packet” qos=0 topic=gateway/XXXXXXXXXXXXXX/stats
Sep 14 14:56:51 Beaglebone lora-gateway-bridge[2388]: time=“2018-09-14T14:56:51Z” level=debug msg=“gateway: sending udp packet to gateway” addr=“127.0.0.1:60253” protocol_version=2 type=PushACK
Sep 14 14:56:51 Beaglebone lora-gateway-bridge[2388]: time=“2018-09-14T14:56:51Z” level=info msg=“backend: config packet received” topic=gateway/XXXXXXXXXXXXXX/config
Sep 14 14:56:51 Beaglebone lora-gateway-bridge[2388]: time=“2018-09-14T14:56:51Z” level=warning msg=“gateway: configuration was not applied, gateway is not configured for managed configuration” mac=XXXXXXXXXXXXXX
Sep 14 14:59:44 Beaglebone lora-app-server[2702]: time=“2018-09-14T14:59:44Z” level=debug msg=“sql query executed” args="[]" duration=5.876875ms query="\n\t\tselect\n\t\t\tg.\n\t\tfrom gateway g\n\t\tinner join network_server ns\n\t\t\ton ns.id = g.network_server_id\n\t\twhere\n\t\t\tns.gateway_discovery_enabled = true\n\t\t\tand g.ping = true\n\t\t\tand (g.last_ping_sent_at is null or g.last_ping_sent_at <= (now() - (interval ‘24 hours’ / ns.gateway_discovery_interval)))\n\t\torder by last_ping_sent_at\n\t\tlimit 1\n\t\tfor update"
Sep 14 14:59:45 Beaglebone lora-app-server[2702]: time=“2018-09-14T14:59:45Z” level=debug msg=“sql query executed” args="[]" duration=6.518584ms query="\n\t\tselect\n\t\t\tg. \n\t\tfrom gateway g\n\t\tinner join network_server ns\n\t\t\ton ns.id = g.network_server_id\n\t\twhere\n\t\t\tns.gateway_discovery_enabled = true\n\t\t\tand g.ping = true\n\t\t\tand (g.last_ping_sent_at is null or g.last_ping_sent_at <= (now() - (interval ‘24 hours’ / ns.gateway_discovery_interval)))\n\t\torder by last_ping_sent_at\n\t\tlimit 1\n\t\tfor update"
Sep 14 15:00:21 Beaglebone loraserver[2399]: time=“2018-09-14T15:00:21Z” level=info msg=“backend/gateway: gateway stats packet received” mac=XXXXXXXXXXXXXX
Sep 14 15:00:21 Beaglebone loraserver[2399]: time=“2018-09-14T15:00:21Z” level=info msg=“gateway updated” mac=XXXXXXXXXXXXXX
Sep 14 15:00:21 Beaglebone loraserver[2399]: time=“2018-09-14T15:00:21Z” level=info msg=“backend/gateway: publishing config packet” qos=0 topic=gateway/XXXXXXXXXXXXXX/config
Sep 14 15:00:51 Beaglebone loraserver[2399]: time=“2018-09-14T15:00:51Z” level=info msg=“backend/gateway: gateway stats packet received” mac=XXXXXXXXXXXXXX
Sep 14 15:00:51 Beaglebone loraserver[2399]: time=“2018-09-14T15:00:51Z” level=info msg=“gateway updated” mac=XXXXXXXXXXXXXX
Sep 14 15:00:51 Beaglebone loraserver[2399]: time=“2018-09-14T15:00:51Z” level=info msg=“backend/gateway: publishing config packet” qos=0 topic=gateway/XXXXXXXXXXXXXX/config
In addition to this the received data paylod shows
uaniTXajI7/7XQNipiAh2g==
what I expect is:
000000000000007F0000000000000000
plus I cant receive any data at live device data.
Where should I start from to fix this ?
brocaar
September 17, 2018, 8:20am
4
Please keep the discussion to the original issue to keep the forum organized. However, your question has been asked before, so probably with a search on the forum you’ll find the solution / hint for your issue
good afternoon could you help me
I am trying to configure the server that works for the region AU_902_928
where I have changed in the file loraserver.toml
[network_server.band]
name = “US_902_928”
enabled_uplink_channels = [0, 1, 2, 3, 4, 5, 6, 7]
and also I made the change in lora-gateway-bridge but now I get this when executing:
sudo systemctl status loraserver
level = error msg = “finished unary call with code unknown” error = “rpc error: code = Unknow desc = lorawan / band: invalid data-rate” grpc.code = unknow grpc.method = sendpropietarypayload grpc.service = ns.networkserverservice grpc.start_time = 2019-07-19T16: 06: 57-05: 00 GRPC.TIME_MS = 0.142 peer.address = 127.0.0.0.1: 41882 span.kinds = server system = grpc
what can i do thanks i’m using lopy4 as nanogateway and node under abp mode
It looks like you have enabled the gateway discovery (under Network Servers in LoRa App Server) with incorrect parameters. That feature is using the “proprietary” MType and will cause these kind of errors when configured incorrectly.
