anyone use Sensative Strips with ChirpStack 3 or 4 (for me its the latest v4 ChirpStack)?
The device joins and send status packets but the payload is not decoded - i use the TTN Device Template for the strip:
From the Event view i see the up packtes:
There is no error in the Events page as it is with an non functional decoder.
This is the Detail window for the packet from 12:06:
Any hints where to start searching for an solution?
Thanks in advance.
PS: One more common question - is there a chance to get the gateway name into the detail information page? With chirpstack v3 it was included.
1337
November 25, 2022, 6:16pm
2
Are 100% sure the payload is not decoded (you mean decrypted right)? I’m only asking to exclude the possibility that your device is just sending something other than what you are expecting.
Hi @1337 ,
i mean decoded with the payload decoder assigned by the device profile - maybe i mix up some things but i expect the decoded values in the Events View up packet as with other devices, dectypt should be a part of the network/application server imho and should work (i case of otaa) with the right AppKey?!
Or did get your answer wrong?
I switched to TTN and there the built in decoder doesnt work too:
If i switch to the decoder provided from sensative (https://gitlab.com/sensative/strips-lora-translator-ttn
the data is decoded:
Here is the decoder after some modification for chirpstack:
// v3 to v4 compatibility wrapper
function decodeUplink(input) {
return {
data: Decode(input.fPort, input.bytes, input.variables)
function encodeDownlink(input) {
return {
bytes: Encode(input.fPort, input.data, input.variables)
function Decode(port, bytes) {
// Decode an uplink message from a buffer
// (array) of bytes to an object of fields.
function decodeFrame(type, target)
switch(type & 0x7f) {
case 0:
target.emptyFrame = {};
break;
case 1: // Battery 1byte 0-100%
target.battery = {};
target.battery = bytes[pos++];
break;
case 2: // TempReport 2bytes 0.1degree C
target.temperature = {}; // celcius 0.1 precision
target.temperature.value = ((bytes[pos] & 0x80 ? 0xFFFF<<16 : 0) | (bytes[pos++] << 8) | bytes[pos++]) / 10;
break;
case 3:
// Temp alarm
target.tempAlarm = {}; // sends alarm after >x<
target.tempAlarm.highAlarm = !!(bytes[pos] & 0x01); // boolean
target.tempAlarm.lowAlarm = !!(bytes[pos] & 0x02); // boolean
pos++;
break;
case 4: // AvgTempReport 2bytes 0.1degree C
target.averageTemperature = {};
target.averageTemperature.value = ((bytes[pos] & 0x80 ? 0xFFFF<<16 : 0) | (bytes[pos++] << 8) | bytes[pos++]) / 10;
break;
case 5:
// AvgTemp alarm
target.avgTempAlarm = {}; // sends alarm after >x<
target.avgTempAlarm.highAlarm = !!(bytes[pos] & 0x01); // boolean
target.avgTempAlarm.lowAlarm = !!(bytes[pos] & 0x02); // boolean
pos++;
break;
case 6: // Humidity 1byte 0-100% in 0.5%
target.humidity = {};
target.humidity.value = bytes[pos++] / 2; // relativeHumidity percent 0,5
break;
case 7: // Lux 2bytes 0-65535lux
target.lux = {};
target.lux.value = ((bytes[pos++] << 8) | bytes[pos++]); // you can the lux range between two sets (lux1 and 2)
break;
case 8: // Lux 2bytes 0-65535lux
target.lux2 = {};
target.lux2.value = ((bytes[pos++] << 8) | bytes[pos++]);
break;
case 9: // DoorSwitch 1bytes binary
target.door = {};
target.door.value = !!bytes[pos++]; // false = door open, true = door closed
break;
case 10: // DoorAlarm 1bytes binary
target.doorAlarm = {};
target.doorAlarm.value = !!bytes[pos++]; // boolean true = alarm
break;
case 11: // TamperReport 1bytes binary (was previously TamperSwitch)
target.tamperReport = {};
target.tamperReport.value = !!bytes[pos++];
break;
case 12: // TamperAlarm 1bytes binary
target.tamperAlarm = {};
target.tamperAlarm.value = !!bytes[pos++];
break;
case 13: // Flood 1byte 0-100%
target.flood = {};
target.flood.value = bytes[pos++]; // percentage, relative wetness
break;
case 14: // FloodAlarm 1bytes binary
target.floodAlarm = {};
target.floodAlarm.value = !!bytes[pos++]; // boolean, after >x<
break;
case 15: // oilAlarm 1bytes analog
target.oilAlarm = {};
target.oilAlarm.value = bytes[pos++];
target.foilAlarm = {}; // Compatibility with older strips
target.foilAlarm.value = !!bytes[pos++];
break;
case 16: // UserSwitch1Alarm, 1 byte digital
target.userSwitch1Alarm = {};
target.userSwitch1Alarm.value = !!bytes[pos++];
break;
case 17: // DoorCountReport, 2 byte analog
target.doorCount = {};
target.doorCount.value = ((bytes[pos++] << 8) | bytes[pos++]);
break;
case 18: // PresenceReport, 1 byte digital
target.presence = {};
target.presence.value = !!bytes[pos++];
break;
case 19: // IRProximityReport
target.IRproximity = {};
target.IRproximity.value = ((bytes[pos++] << 8) | bytes[pos++]);
break;
case 20: // IRCloseProximityReport, low power
target.IRcloseproximity = {};
target.IRcloseproximity.value = ((bytes[pos++] << 8) | bytes[pos++]);
break;
case 21: // CloseProximityAlarm, something very close to presence sensor
target.closeProximityAlarm = {};
target.closeProximityAlarm.value = !!bytes[pos++];
break;
case 22: // DisinfectAlarm
target.disinfectAlarm = {};
target.disinfectAlarm.value = bytes[pos++];
if (target.disinfectAlarm.value === 0) target.disinfectAlarm.state='dirty';
if (target.disinfectAlarm.value == 1) target.disinfectAlarm.state='occupied';
if (target.disinfectAlarm.value == 2) target.disinfectAlarm.state='cleaning';
if (target.disinfectAlarm.value == 3) target.disinfectAlarm.state='clean';
break;
case 80:
target.temperature = ((bytes[pos] & 0x80 ? 0xFFFF<<16 : 0) | (bytes[pos++] << 8) | bytes[pos++]) / 10;
break;
case 81:
break;
case 82:
target.door = {};
target.door.value = !!bytes[pos++]; // true = door open, false = door closed
break;
case 112: // Capacitance Raw Sensor Value 2bytes 0-65535
target.capacitanceFlood = {};
target.capacitanceFlood.value = ((bytes[pos++] << 8) | bytes[pos++]); // should never trigger anymore
break;
case 113: // Capacitance Raw Sensor Value 2bytes 0-65535
target.capacitancePad = {};
target.capacitancePad.value = ((bytes[pos++] << 8) | bytes[pos++]); // should never trigger anymore
break;
case 110:
pos += 8;
break;
case 114: // Capacitance Raw Sensor Value 2bytes 0-65535
target.capacitanceEnd = {};
target.capacitanceEnd.value = ((bytes[pos++] << 8) | bytes[pos++]); // should never trigger anymore
break;
var decoded = {};
var pos = 0;
var type;
switch(port) {
case 1:
if(bytes.length < 2) {
decoded.error = 'Wrong length of RX package';
break;
decoded.historySeqNr = (bytes[pos++] << 8) | bytes[pos++];
decoded.prevHistSeqNr = decoded.historySeqNr;
while(pos < bytes.length) {
type = bytes[pos++];
if(type & 0x80)
decoded.prevHistSeqNr--;
decodeFrame(type, decoded);
break;
case 2:
var now = new Date();
decoded.history = {};
decoded.history.error = 'Wrong length of RX package';
break;
var seqNr = (bytes[pos++] << 8) | bytes[pos++];
decoded.history[seqNr] = {};
decoded.history.now = now.toUTCString();
secondsAgo = (bytes[pos++] << 24) | (bytes[pos++] << 16) | (bytes[pos++] << 8) | bytes[pos++];
decoded.history[seqNr].timeStamp = new Date(now.getTime() - secondsAgo*1000).toUTCString();
decodeFrame(type, decoded.history[seqNr]);
seqNr++;
return decoded;
With success:
Regards
