Has anyone successfully installed the GatewayOS on a Seeed M2 gateway. When I try I get this, “It appears that you are trying to flash an image that does not fit into the flash memory, please verify the image file!”
Continue is not enabled.
Hi, I have the same problem. I need to use the full installation of Chirpstack on the Sensecap M2, because the version running natively on the the Sensecap does not have Node Red … hopefully someone can answer this soon
Could you try to first flash the Seeed open-source firmware? Releases · Seeed-Solution/LoRa_Gateway_OpenWRT · GitHub
This is the path I have tried and I do not get this error.
