Hi there to all the community!
I installed the ChirpstackOS on a SENSECAP M2 gateway, expecting to upgrade from the opensource software it had.
Unfortunatelly, there is no “full image” for tha model and consequently I can’t use it in server mode!!!
Is there a way to port the APP Server and consequently the LoRaWan Network server? I understand for example if NodeRED doesn´t fit because of low capacity of the gateway but, Network Server would be very important!
There is no full image for any of the other gateways either. The pre-installed LNS on the M2 gateway is limited (no SSL; MQTT/http integration only etc; cannot be configured). It would be interesting to know if a default Chirpstack LNS install runs OK on the gateway…
The cheapest solution may well be to get a Pi Zero and run the LNS on that instead of on the gateway.
