Server with 1 region with several gateways with individual frequency plans
Hi
First of all, thanks for this great solution, its a pleasure to use it!
To cover a high-density area with lora devices, I was thinking to use chirpstack 4 (AU915) with 6 gateway bridges (every gateway-bridge for 1 frequency band, like AU915_0, AU915_1 and AU915_3, etc. and 3 gateways with 8 or 16 channels, where every gateway is using the relative gateway-bridge.
On the gateways, basicstation would be my preferred solution.
Can this work or is another solution required, what solution would be the best?
Many thanks for any advice
Stefan
If I understand correctly, yes this can work. Basically you have different sub-region configs and each gateway is tied to one of these sub-regions (_0, _1, _2, …). Make sure you configure the MQTT topic prefix correctly :slight_smile:
