Hello community,
I’ve recently set up an Ubuntu server and successfully cloned the ChirpStack Git repository from [GitHub - chirpstack/chirpstack-docker: Setup ChirpStack using Docker Compose]. Within the provided Docker Compose file, I’ve configured both ThingsBoard and Node-RED, and they’re currently operational.
Now, is it possible of establishing a separate database for ThingsBoard in PostgreSQL as we already have chirpstack database configured for PostgreSQL . If this is possible, could someone kindly guide me through the necessary configurations? Below, I’ve included the YAML file with the current configurations. Any assistance would be immensely appreciated. Thank you.
version: “3”
services:
chirpstack:
image: chirpstack/chirpstack:4
command: -c /etc/chirpstack
restart: unless-stopped
volumes:
- ./lorawan-devices:/opt/lorawan-devices
depends_on:
- postgres
- mosquitto
- redis
environment:
- MQTT_BROKER_HOST=mosquitto
- REDIS_HOST=redis
- POSTGRESQL_HOST=postgres
ports:
- 8080:8080
thingsboard:
image: thingsboard/tb-postgres
volumes:
- thingsboarddata:/data
ports:
- 9090:9090
chirpstack-gateway-bridge:
image: chirpstack/chirpstack-gateway-bridge:4
ports:
- 1700:1700/udp
volumes:
environment:
- INTEGRATION__MQTT__EVENT_TOPIC_TEMPLATE=eu868/gateway/{{ .GatewayID }}/event/{{ .EventType }}
- INTEGRATION__MQTT__STATE_TOPIC_TEMPLATE=eu868/gateway/{{ .GatewayID }}/state/{{ .StateType }}
- INTEGRATION__MQTT__COMMAND_TOPIC_TEMPLATE=eu868/gateway/{{ .GatewayID }}/command/#
depends_on:
- mosquitto
chirpstack-gateway-bridge-basicstation:
command: -c /etc/chirpstack-gateway-bridge/chirpstack-gateway-bridge-basicstation-eu868.toml
ports:
- 3001:3001
volumes:
depends_on:
- mosquitto
chirpstack-rest-api:
image: chirpstack/chirpstack-rest-api:4
command: --server chirpstack:8080 --bind 0.0.0.0:8090 --insecure
ports:
- 8090:8090
depends_on:
- chirpstack
postgres:
image: postgres:14-alpine
volumes:
environment:
- POSTGRES_PASSWORD=root
redis:
image: redis:7-alpine
command: redis-server --save 300 1 --save 60 100 --appendonly no
volumes:
- redisdata:/data
mosquitto:
image: eclipse-mosquitto:2
ports:
- 1883:1883
volumes:
- ./configuration/mosquitto/config/:/mosquitto/config/
node-red:
image: nodered/node-red
environment:
- TZ=Europe/Berlin
ports:
- 1880:1880
networks:
- node-red-net
volumes:
- node-red-data:/data
volumes:
postgresqldata:
redisdata:
thingsboarddata:
node-red-data:
networks:
node-red-net:
