Setting up class b
im building a small project that has a few types of end nodes, some working with class a and some need to be working with class b or c
im trying to set it up in chirpstack server and i set the device profile according to rp1.0.4 under region as923
im having trouble with the code of the end nodes, as soon as i try to set up class b i either dont get class b to work and get ev_scan_timeout or i get join request without join accept
checking the gateway logs i see that for some reason the join request is 50 min ahead of join accept (the gateway send join accept right away but the end node doesnt get it)
anyway im going bald from pulling my hair from having this not working if anyone can take a look would be appreciated
note that i have 2 onEvent versions, one is commented out cuz i thought maybe that was the probelm
heres the full code of the end node
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include "LIDARLite_v3HP.h"
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "freertos/semphr.h"
#include "DFRobotDFPlayerMini.h"
#include <ttn_keys.h>
#include <lmic.h>
#include <hal/hal.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define LED 2
#define NUM_MEASUREMENTS 10
#define THRESHOLD_PERCENTAGE 0.05
#define dfplayer_RX 16
#define dfplayer_TX 17
#define default_volume 15
#define nss_pin 5
#define rst_pin 14
#define dio0_pin 26
#define dio1_pin 35
#define dio2_pin 34
#define OLED_RESET -1
// LoRa commands
#define STATUS_REQUEST 0x01
#define RESET_REQUEST 0x02
#define DATA_COLLECTION_REQUEST 0x03
#define ALERT_NOTIFICATION 0xFF
// Button setup
#define output_pin 12
#define input_pin 13
// Function prototypes
void playAlertSound();
void handle_command(uint8_t command);
int getLatestDistance();
// void initButton();
// Global variables
uint8_t mydata[50] = "Device online";
static osjob_t sendjob;
// volatile bool buttonPressed = false;  // A flag to indicate button press
#ifdef DEV_UNIT
  const unsigned TX_INTERVAL = 30;
#else
  const unsigned TX_INTERVAL = 120;
#endif
bool isFirstTransmission = true;
// LoRa configuration
static const u1_t PROGMEM DEVEUI[8]  = _DEVEUI;
static const u1_t PROGMEM APPEUI[8]  = _APPEUI;
static const u1_t PROGMEM APPKEY[16] = _APPKEY;
void os_getArtEui(u1_t* buf) { memcpy_P(buf, APPEUI, 8); }
void os_getDevEui(u1_t* buf) { memcpy_P(buf, DEVEUI, 8); }
void os_getDevKey(u1_t* buf) { memcpy_P(buf, APPKEY, 16); }
const lmic_pinmap lmic_pins = {
    .nss = nss_pin,
    .rxtx = LMIC_UNUSED_PIN,
    .rst = rst_pin,
    .dio = {dio0_pin, dio1_pin, dio2_pin},
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
LIDARLite_v3HP myLidarLite;
HardwareSerial myDFPlayerSerial(2);
DFRobotDFPlayerMini myDFPlayer;
TaskHandle_t led_blink_task_handle = NULL;
TaskHandle_t measureDistance_task_handle = NULL;
TaskHandle_t averageCalculation_task_handle = NULL;
TaskHandle_t lora_task_handle = NULL;
TaskHandle_t simAlertTask_handle = NULL;
SemaphoreHandle_t i2c_mutex;
SemaphoreHandle_t alert_semaphore;
SemaphoreHandle_t distance_semaphore;
int distanceMeasurements[NUM_MEASUREMENTS] = {0};
int measurementIndex = 0;
int baselineDistance = 0;
int thresholdDistance = 0;
unsigned long int measurementNumber = 0;
// Add this helper function for printing hex values
void printHex2(unsigned v) {
    v &= 0xff;
    if (v < 16)
        Serial.print('0');
    Serial.print(v, HEX);
void enableClassB() {
    LMIC_enableTracking(1);
    LMIC_setPingable(0);
    Serial.println(F("Class B enabled"));
// Modify the do_send function to avoid repeated sends
void do_send(osjob_t* j) {
    // Check if there is not a current TX/RX job running
    if (LMIC.opmode & OP_TXRXPEND) {
        Serial.println(F("OP_TXRXPEND, not sending"));
    } else {
        // if (isFirstTransmission) {
        //     isFirstTransmission = false;
        //     strcpy((char*)mydata, "Routine status");
        // Prepare upstream data transmission at the next possible time.
        LMIC_setTxData2(1, mydata, strlen((char*)mydata), 0);
        Serial.println(F("Packet queued"));
        Serial.print("Sending message: ");
        Serial.println((char*)mydata);
        Serial.print("Frame counter: ");
        Serial.println(LMIC.seqnoUp);
        // Next TX should reutrn to status
    // Next TX is scheduled after TX_COMPLETE event.
void onEvent (ev_t ev) {
    Serial.print(os_getTime());
    Serial.print(": ");
    switch(ev) {
        case EV_SCAN_TIMEOUT:
            Serial.println(F("EV_SCAN_TIMEOUT"));
            break;
        case EV_BEACON_FOUND:
            LMIC_sendAlive();
            Serial.println(F("EV_BEACON_FOUND"));
            break;
        case EV_BEACON_MISSED:
            Serial.println(F("EV_BEACON_MISSED"));
            break;
        case EV_BEACON_TRACKED:
            Serial.println(F("EV_BEACON_TRACKED"));
            break;
        case EV_JOINING:
            Serial.println(F("EV_JOINING"));
            break;
        case EV_JOINED:
            Serial.println(F("EV_JOINED"));
              u4_t netid = 0;
              devaddr_t devaddr = 0;
              u1_t nwkKey[16];
              u1_t artKey[16];
              LMIC_getSessionKeys(&netid, &devaddr, nwkKey, artKey);
              Serial.print("netid: ");
              Serial.println(netid, DEC);
              Serial.print("devaddr: ");
              Serial.println(devaddr, HEX);
              Serial.print("AppSKey: ");
              for (size_t i=0; i<sizeof(artKey); ++i) {
                if (i != 0)
                  Serial.print("-");
                printHex2(artKey[i]);
              Serial.println("");
              Serial.print("NwkSKey: ");
              for (size_t i=0; i<sizeof(nwkKey); ++i) {
                      if (i != 0)
                              Serial.print("-");
                      printHex2(nwkKey[i]);
              Serial.println();
            // Disable link check validation (automatically enabled
            // during join, but because slow data rates change max TX
	    // size, we don't use it in this example.
            LMIC_setLinkCheckMode(0);
            #if defined(WEARABLE_UNIT)
              enableClassB();
            #endif
            break;
        || This event is defined but not used in the code. No
        || point in wasting codespace on it.
        || case EV_RFU1:
        ||     Serial.println(F("EV_RFU1"));
        ||     break;
        case EV_JOIN_FAILED:
            Serial.println(F("EV_JOIN_FAILED"));
            break;
        case EV_REJOIN_FAILED:
            Serial.println(F("EV_REJOIN_FAILED"));
            break;
        case EV_TXCOMPLETE:
            Serial.println(F("EV_TXCOMPLETE (includes waiting for RX windows)"));
            if (LMIC.txrxFlags & TXRX_ACK)
              Serial.println(F("Received ack"));
            if (LMIC.dataLen) {
              Serial.print(F("Received "));
              Serial.print(LMIC.dataLen);
              Serial.println(F(" bytes of payload"));
            // Schedule next transmission
            os_setTimedCallback(&sendjob, os_getTime()+sec2osticks(TX_INTERVAL), do_send);
            break;
        case EV_LOST_TSYNC:
            Serial.println(F("EV_LOST_TSYNC"));
            break;
        case EV_RESET:
            Serial.println(F("EV_RESET"));
            break;
        case EV_RXCOMPLETE:
            // data received in ping slot
            Serial.println(F("EV_RXCOMPLETE"));
            if (LMIC.dataLen) {
                for (int i = 0; i < LMIC.dataLen; i++) {
                    if (LMIC.frame[LMIC.dataBeg + i] < 0x10) {
                        Serial.print("0");
                    Serial.print(LMIC.frame[LMIC.dataBeg + i], HEX);
                    Serial.print(" ");
            break;
        case EV_LINK_DEAD:
            Serial.println(F("EV_LINK_DEAD"));
            break;
        case EV_LINK_ALIVE:
            Serial.println(F("EV_LINK_ALIVE"));
            break;
        || case EV_SCAN_FOUND:
        ||    Serial.println(F("EV_SCAN_FOUND"));
        ||    break;
        case EV_TXSTART:
            Serial.println(F("EV_TXSTART"));
            break;
        case EV_TXCANCELED:
            Serial.println(F("EV_TXCANCELED"));
            break;
        case EV_RXSTART:
            /* do not print anything -- it wrecks timing */
            break;
        case EV_JOIN_TXCOMPLETE:
            Serial.println(F("EV_JOIN_TXCOMPLETE: no JoinAccept"));
            break;
        default:
            Serial.print(F("Unknown event: "));
            Serial.println((unsigned) ev);
            break;
// void onEvent(ev_t ev) {
//     Serial.print(os_getTime());
//     Serial.print(": ");
//     switch(ev) {
//         case EV_SCAN_TIMEOUT:
//             Serial.println(F("EV_SCAN_TIMEOUT"));
//             // LMIC_sendAlive();
//             break;
//         // #if defined(WEARABLE_UNIT)
//         case EV_BEACON_FOUND:
//             // Serial.println(F("EV_BEACON_FOUND"));
//             // display.clearDisplay();
//             // display.println("Beacon found");
//             // display.display();
//             break;
//         // #endif
//         case EV_BEACON_MISSED:
//             Serial.println(F("EV_BEACON_MISSED"));
//             break;
//         case EV_BEACON_TRACKED:
//             Serial.println(F("EV_BEACON_TRACKED"));
//             break;
//         case EV_JOINING:
//             Serial.println(F("EV_JOINING"));
//             break;
//         case EV_JOINED:
//             Serial.println(F("EV_JOINED"));
//               u4_t netid = 0;
//               devaddr_t devaddr = 0;
//               u1_t nwkKey[16];
//               u1_t artKey[16];
//               LMIC_getSessionKeys(&netid, &devaddr, nwkKey, artKey);
//               Serial.print("netid: ");
//               Serial.println(netid, DEC);
//               Serial.print("devaddr: ");
//               Serial.println(devaddr, HEX);
//               Serial.print("AppSKey: ");
//               for (size_t i=0; i<sizeof(artKey); ++i) {
//                 if (i != 0)
//                   Serial.print("-");
//                 printHex2(artKey[i]);
//               Serial.println("");
//               Serial.print("NwkSKey: ");
//               for (size_t i=0; i<sizeof(nwkKey); ++i) {
//                       if (i != 0)
//                       printHex2(nwkKey[i]);
//               Serial.println();
//             // Disable link check validation (automatically enabled
//             // during join, but because slow data rates change max TX
//             // size, we don't use it in this example.
//             LMIC_setLinkCheckMode(0);
//             // LMIC_setPingable(0);
//             // Send "Device online" message
//               enableClassB();
//             // #else
//               strcpy((char*)mydata, "Device online");
//               do_send(&sendjob);
//             // #endif
//             break;
//             break;
//         case EV_RFU1:
//             Serial.println(F("EV_RFU1"));
//             break;
//         case EV_JOIN_FAILED:
//             Serial.println(F("EV_JOIN_FAILED"));
//             break;
//         case EV_REJOIN_FAILED:
//             Serial.println(F("EV_REJOIN_FAILED"));
//             break;
//         case EV_TXSTART:
//             Serial.println(F("EV_TXSTART"));
//             break;
//         case EV_TXCOMPLETE:
//             Serial.println(F("EV_TXCOMPLETE (includes waiting for RX windows)"));
//             if (LMIC.txrxFlags & TXRX_ACK)
//                 Serial.println(F("Received ack"));
//             if (LMIC.dataLen) {
//                 Serial.print(F("Received "));
//                 Serial.print(LMIC.dataLen);
//                 Serial.println(F(" bytes of payload"));
//                 for (int i = 0; i < LMIC.dataLen; i++) {
//                     if (LMIC.frame[LMIC.dataBeg + i] < 0x10) {
//                         Serial.print("0");
//                     Serial.print(LMIC.frame[LMIC.dataBeg + i], HEX);
//                     Serial.print(" ");
//                 if (LMIC.dataLen > 0) {
//                     handle_command(LMIC.frame[LMIC.dataBeg]);
//                 display.println("Received data");
//                 #endif
//             // Schedule next transmission
//             // #if !defined(WEARABLE_UNIT)
//                 // os_setTimedCallback(&sendjob, os_getTime() + sec2osticks(TX_INTERVAL), do_send);
//             // #endif
//             break;
//         case EV_JOIN_TXCOMPLETE:
//             Serial.println(F("EV_JOIN_TXCOMPLETE"));
//             break;
//         default:
//             Serial.println(F("Unknown event"));
//             Serial.println((unsigned) ev);
//             break;
void handle_command(uint8_t command) {
    switch(command) {
        case STATUS_REQUEST:
            Serial.println("Received STATUS_REQUEST");
            strcpy((char*)mydata, "Status: Device is operational");
            do_send(&sendjob);
            break;
        case RESET_REQUEST:
            Serial.println("Received RESET_REQUEST");
            strcpy((char*)mydata, "Reset: Device is resetting");
            do_send(&sendjob);
            // ESP.restart();
            break;
        case DATA_COLLECTION_REQUEST:
            Serial.println("Received DATA_COLLECTION_REQUEST");
                int distance = getLatestDistance();
                snprintf((char*)mydata, sizeof(mydata), "Data: Latest distance is %d cm", distance);
                do_send(&sendjob);
            break;
        case ALERT_NOTIFICATION:
            #if defined(DEV_UNIT) || defined(WEARABLE_UNIT)
                display.setTextSize(2);
                display.setTextColor(SSD1306_WHITE);
                display.setCursor(0, 0);
                display.println("DEVALERT");
                display.display();
            #endif
            #if defined(DEV_UNIT) || defined(MUSICBOX_UNIT)
                playAlertSound();
            #endif
            Serial.println("Alert notification received");
            break;
        default:
            Serial.println("Unknown command received");
            break;
void led_blink_task(void *pvParameters) {
    pinMode(LED, OUTPUT);
    while (true) {
        digitalWrite(LED, HIGH);
        vTaskDelay(1000 / portTICK_PERIOD_MS);
        digitalWrite(LED, LOW);
void lcd_init() {
    if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
        Serial.println(F("SSD1306 allocation failed"));
        for (;;);
    display.display();
    vTaskDelay(2000 / portTICK_PERIOD_MS);
    display.display();
void measureDistance_task(void *pvParameters) {
    while (true) {
        xSemaphoreTake(i2c_mutex, portMAX_DELAY);
        myLidarLite.takeRange();
        int distance = myLidarLite.readDistance();
        xSemaphoreGive(i2c_mutex);
        distanceMeasurements[measurementIndex] = distance;
        measurementIndex = (measurementIndex + 1) % NUM_MEASUREMENTS;
        measurementNumber++;
        xSemaphoreGive(distance_semaphore);
        vTaskDelay(1);
  myDFPlayer.play(1); // Play the first track on the SD card
// Modify the averageCalculation_task to add more debug output and avoid constant alerts
void averageCalculation_task(void *pvParameters) {
    static uint32_t lastAlertTime = 0;
    const uint32_t alertCooldown = 100; // 60 seconds cooldown between alerts
    while (true) {
        if (xSemaphoreTake(distance_semaphore, portMAX_DELAY) == pdTRUE) {
            int sum = 0;
            for (int i = 0; i < NUM_MEASUREMENTS; i++) {
                sum += distanceMeasurements[i];
            int averageDistance = sum / NUM_MEASUREMENTS;
            int distance = distanceMeasurements[(measurementIndex - 1 + NUM_MEASUREMENTS) % NUM_MEASUREMENTS];
            // Serial.printf("Current distance: %d cm, Average: %d cm, Baseline: %d cm, Threshold: %d cm\n",
            //               distance, averageDistance, baselineDistance, thresholdDistance);
            uint32_t currentTime = millis();
            if (abs(distance - baselineDistance) > thresholdDistance &&
                (currentTime - lastAlertTime > alertCooldown)) {
                strcpy((char*)mydata, "Alert: Distance threshold exceeded");
                do_send(&sendjob);
                lastAlertTime = currentTime;
                Serial.println("Alert triggered!");
                #ifdef DEV_UNIT
                display.println("ALERT!");
                display.display();
                playAlertSound();
                #endif
        vTaskDelay(1 / portTICK_PERIOD_MS); // Check every second instead of continuously
void calibrateSensor() {
    int sum = 0;
        vTaskDelay(10 / portTICK_PERIOD_MS);
        sum += distance;
        vTaskDelay(100 / portTICK_PERIOD_MS);
    baselineDistance = sum / NUM_MEASUREMENTS;
    thresholdDistance = baselineDistance * THRESHOLD_PERCENTAGE;
    Serial.printf("Calibration complete. Baseline: %d cm, Threshold: %d cm\n", baselineDistance, thresholdDistance);
void lora_task(void *pvParameters) {
    while (true) {
        os_runloop_once();
        vTaskDelay(1);
int getLatestDistance() {
    return distanceMeasurements[(measurementIndex - 1 + NUM_MEASUREMENTS) % NUM_MEASUREMENTS];
void simAlertTask(void *pvParameters) {
    while(1){
        strcpy((char*)mydata, "Simulated Alert: Distance threshold exceeded");
        do_send(&sendjob);
        Serial.println("Simulated Alert triggered!");
        vTaskDelay( 200000 / portTICK_PERIOD_MS);
void setup() {
    Serial.begin(115200);
    lcd_init();
    #endif
    #if defined(DEV_UNIT) || defined(LIDAR_UNIT)
    myLidarLite.configure(0);
    #endif
    i2c_mutex = xSemaphoreCreateMutex();
    alert_semaphore = xSemaphoreCreateBinary();
    distance_semaphore = xSemaphoreCreateBinary();
    if (i2c_mutex == NULL || alert_semaphore == NULL || distance_semaphore == NULL) {
        Serial.println("Failed to create semaphores");
        while (1);
    calibrateSensor();
    #endif
    myDFPlayerSerial.begin(9600, SERIAL_8N1, dfplayer_RX, dfplayer_TX);
    if (!myDFPlayer.begin(myDFPlayerSerial)) {
        Serial.println(F("Unable to begin DFPlayer Mini"));
        while (true);
    Serial.println(F("DFPlayer Mini online."));
    myDFPlayer.volume(default_volume);
    #endif
    Serial.println("asdf");
    #endif
    os_init();
    LMIC_reset();
    // LMIC_setClockError(MAX_CLOCK_ERROR * 10 / 100);
    LMIC_startJoining();
    xTaskCreatePinnedToCore(led_blink_task, "blinkled", 2048, NULL, 1, &led_blink_task_handle, 0);
    #endif
    xTaskCreatePinnedToCore(measureDistance_task, "getDistance", 2048, NULL, 3, &measureDistance_task_handle, 0);
    xTaskCreatePinnedToCore(averageCalculation_task, "averageCalc", 2048, NULL, 2, &averageCalculation_task_handle, 0);
    #endif
    #if defined(LIDAR_UNIT_SIM)
    xTaskCreatePinnedToCore(simAlertTask,"simAlert",2048,NULL,2,&simAlertTask_handle,0);
    #endif
    xTaskCreatePinnedToCore(lora_task, "loraTask", 4096, NULL, 1, &lora_task_handle, 1);
void loop() {
    // Empty loop since everything is handled by FreeRTOS tasks
