I’m trying, to simulate UDP packet to Gateway bridge with python, and I plan after having passed this stage, to change manually the payload. I followed precisely the documentation below :
Lora-net/packet_forwarder
how encode the byte :
I modified the file. .toml configuration of the gateway bridge:
marshaler="json"
i try to see the example test in the link below :
My python script :
import socket
import time
import json
import binascii
UDP_IP_ADDRESS = "127.0.0.1"
UDP_PORT_NO = 1700
PAYLOAD = '{"rxpk":[{"time":"2013-03-31T16:21:17.532038Z","tmst":3316387610,"chan":0,"rfch":0,"freq":863.00981,"stat":1,"modu":"LORA","datr":"SF10BW125","codr":"4/7","rssi":-38,"lsnr":5.5,"size":32,"data":"ysgRl452xNLep9S1NTIg2lomKDxUgn3DJ7DE+b00Ass"}]}'.encode("utf-8")
MAC = "ABCDEF1010101010"
hex_mac =bytes.fromhex(MAC)
frame = b'\2' # 0 for protocole version
frame += b'\7' # byte 1 random token
frame += b'\5' # byte 2 random token
frame += b'\0' # push data identifier
frame += hex_mac
frame += PAYLOAD
print(frame)
while True:
clientSock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
clientSock.sendto(frame, (UDP_IP_ADDRESS, UDP_PORT_NO))
time.sleep(5)
unfortunately when i run the script, the gateway brige gives me a base 64 format error, see below :
Jan 15 11:51:40 B827EBFFFEF65A01 chirpstack-gateway-bridge[3821]: time="2020-01-15T11:51:40Z" level=error msg="backend/semtechudp: could not handle packet" addr="127.0.0.1:50002" data_base64="AgcFAKvN7xAQEBAQeyJyeHBrIjpbeyJ0aW1lIjoiMjAxMy0wMy0zMVQxNjoyMToxNy41MzIwMzhaIiwidG1zdCI6MzMxNjM4NzYxMCwiY2hhbiI6MCwicmZjaCI6MCwiZnJlcSI6ODYzLjAwOTgxLCJzdGF0IjoxLCJtb2R1IjoiTE9SQSIsImRhdHIiOiJTRjEwQlcxMjUiLCJjb2RyIjoiNC83IiwicnNzaSI6LTM4LCJsc25yIjo1LjUsInNpemUiOjMyLCJkYXRhIjoieXNnUmw0NTJ4TkxlcDlTMU5USWcybG9tS0R4VWduM0RKN0RFK2IwMEFzcyJ9XX0=" error="illegal base64 data at input byte 40"
Can some one help me to make the good udp packet format !! thanks.
