Hi @chopmann,
Thank you for your reply, as I understood for LPP format. I got that there is no need for decoder. the packet is already decoded. I forgor to mention that my mistake.
I also trying to send queue downlink to corntol relay “open 03 00 64 FF/ close 03 00 00 FF”, but also I failed to do it.
I have attached the sketch and screenshots for receiving data on App server.
Regards
#include <dht.h>
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
dht DHT;
#define DHT11_PIN A0
#define SensorPin A1
int moistureValue = -1;
const int ctl_pin=4; //define the output pin of realy
const int flame_pin=3; //define the input pin of flame sensor I DONOT NEED IT
// This EUI must be in little-endian format, so least-significant-byte
// first. When copying an EUI from ttnctl output, this means to reverse
// the bytes. For TTN issued EUIs the last bytes should be 0xD5, 0xB3,
// 0x70.
static const u1_t PROGMEM APPEUI[8]={ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
void os_getArtEui (u1_t* buf) { memcpy_P(buf, APPEUI, 8);}
// This should also be in little endian format, see above.
static const u1_t PROGMEM DEVEUI[8]={****************************** };
void os_getDevEui (u1_t* buf) { memcpy_P(buf, DEVEUI, 8);}
// This key should be in big endian format (or, since it is not really a
// number but a block of memory, endianness does not really apply). In
// practice, a key taken from ttnctl can be copied as-is.
// The key shown here is the semtech default key.
static const u1_t PROGMEM APPKEY[16] ={************************************************************************};
void os_getDevKey (u1_t* buf) { memcpy_P(buf, APPKEY, 16);}
static float temperature,humidity,tem,hum;
static uint8_t LPP_data[17] = {0x01,0x67,0x00,0x00,0x02,0x68,0x00,0x03,0x01,0x00,0x04,0x00,0x00,0x05,0x67,0x00,0x00}; //0xO1,0x02,0x03,0x04 is Data Channel,0x67,0x68,0x01,0x00 is Data Type
static uint8_t opencml[4]={0x03,0x00,0x64,0xFF},closecml[4]={0x03,0x00,0x00,0xFF}; //the payload of the cayenne or ttn downlink
static unsigned int count = 1;
static osjob_t sendjob;
// Schedule TX every this many seconds (might become longer due to duty
// cycle limitations).
const unsigned TX_INTERVAL = 31;
// Pin mapping
const lmic_pinmap lmic_pins = {
.nss = 10,
.rxtx = LMIC_UNUSED_PIN,
.rst = 9,
.dio = {2, 6, 7},
void onEvent (ev_t ev) {
Serial.print(os_getTime());
Serial.print(": ");
switch(ev) {
case EV_SCAN_TIMEOUT:
Serial.println(F("EV_SCAN_TIMEOUT"));
break;
case EV_BEACON_FOUND:
Serial.println(F("EV_BEACON_FOUND"));
break;
case EV_BEACON_MISSED:
Serial.println(F("EV_BEACON_MISSED"));
break;
case EV_BEACON_TRACKED:
Serial.println(F("EV_BEACON_TRACKED"));
break;
case EV_JOINING:
Serial.println(F("EV_JOINING"));
break;
case EV_JOINED:
Serial.println(F("EV_JOINED"));
// Disable link check validation (automatically enabled
// during join, but not supported by TTN at this time).
LMIC_setLinkCheckMode(0);
break;
case EV_RFU1:
Serial.println(F("EV_RFU1"));
break;
case EV_JOIN_FAILED:
Serial.println(F("EV_JOIN_FAILED"));
break;
case EV_REJOIN_FAILED:
Serial.println(F("EV_REJOIN_FAILED"));
break;
break;
case EV_TXCOMPLETE:
Serial.println(F("EV_TXCOMPLETE (includes waiting for RX windows)"));
if (LMIC.txrxFlags & TXRX_ACK)
Serial.println(F("Received ack"));
if(LMIC.dataLen>0)
int i,j=0;
uint8_t received[4]={0x00,0x00,0x00,0x00};
Serial.println("Received :");
for(i=9;i<(9+LMIC.dataLen);i++) //the received buf
Serial.print(LMIC.frame[i],HEX);
received[j]=LMIC.frame[i];
j++;
Serial.print(" ");
Serial.println();
//comparing incoming msg "downlink" with defined value of open relay "open cml"
//in case of this statement TRUE the follwing commands will excute, otherwise jump to next statement.
if ((received[0]==opencml[0])&&(received[1]==opencml[1])&&(received[2]==opencml[2])&&(received[3]==opencml[3])) {
Serial.println("Set pin to HIGH.");
digitalWrite(ctl_pin, HIGH);
if ((received[0]==closecml[0])&&(received[1]==closecml[1])&&(received[2]==closecml[2])&&(received[3]==closecml[3])) {
Serial.println("Set pin to LOW.");
digitalWrite(ctl_pin, LOW);
// Schedule next transmission
os_setTimedCallback(&sendjob, os_getTime()+sec2osticks(TX_INTERVAL), do_send);
break;
case EV_LOST_TSYNC:
Serial.println(F("EV_LOST_TSYNC"));
break;
case EV_RESET:
Serial.println(F("EV_RESET"));
break;
case EV_RXCOMPLETE:
// data received in ping slot
Serial.println(F("EV_RXCOMPLETE"));
break;
case EV_LINK_DEAD:
Serial.println(F("EV_LINK_DEAD"));
break;
case EV_LINK_ALIVE:
Serial.println(F("EV_LINK_ALIVE"));
break;
default:
Serial.println(F("Unknown event"));
break;
void dhtTem()
int16_t tem_LPP;
temperature = DHT.read11(DHT11_PIN); //Read Tmperature data
tem = DHT.temperature*1.0;
humidity = DHT.read11(DHT11_PIN); //Read humidity data
hum = DHT.humidity* 1.0;
int moistureValue = analogRead(SensorPin); // soil moisture value
int result= map(moistureValue,550,243,0,100);
Serial.print("########### ");
Serial.print("COUNT=");
Serial.print(count);
Serial.println(" ###########");
Serial.println(F("The temperature and humidity:"));
Serial.print("[");
Serial.print(tem);
Serial.print("℃");
Serial.print(",");
Serial.print(hum);
Serial.print("%");
Serial.print("]");
Serial.println("");
Serial.print("moisture is: ");
Serial.println(result);
count++;
tem_LPP=tem * 10;
LPP_data[2] = tem_LPP>>8;
LPP_data[3] = tem_LPP;
LPP_data[6] = hum * 2;
LPP_data[15]= result;
void pinread()
int val,val1;
val=digitalRead(ctl_pin);
val1=digitalRead(flame_pin);
if(val==1)
LPP_data[9]=0x01;
else
LPP_data[9]=0x00;
if(val1==1)
LPP_data[12]=0x01;
else
LPP_data[12]=0x00;
void do_send(osjob_t* j){
// Check if there is not a current TX/RX job running
if (LMIC.opmode & OP_TXRXPEND) {
Serial.println(F("OP_TXRXPEND, not sending"));
} else {
dhtTem();
pinread();
// int -> byte array
// byte payload[2];
//payload[0] = lowByte(sensorValue);
//payload[1] = highByte(sensorValue);
// Prepare upstream data transmission at the next possible time.
LMIC_setTxData2(1,LPP_data, sizeof(LPP_data), 0);
Serial.println(F("Packet queued"));
// Next TX is scheduled after TX_COMPLETE event.
void setup() {
Serial.begin(9600);
while(!Serial);
Serial.println("Connect to TTN and Send data to mydevice cayenne(Use DHT11 Sensor):");
pinMode(ctl_pin,OUTPUT);
pinMode(flame_pin,INPUT);
// attachInterrupt(1,fire,LOW); //no connect Flame sensor should commented this code
#ifdef VCC_ENABLE
// For Pinoccio Scout boards
pinMode(VCC_ENABLE, OUTPUT);
digitalWrite(VCC_ENABLE, HIGH);
delay(1000);
#endif
// LMIC init
os_init();
// Reset the MAC state. Session and pending data transfers will be discarded.
LMIC_reset();
// Start job (sending automatically starts OTAA too)
do_send(&sendjob);
void fire()
LPP_data[12]=0x00;
dhtTem();
Serial.println("Have fire,the temperature is send");
void loop() {
os_runloop_once();
