[Problem solved: it occurs that Chirpstack remote server uses udp or mqtts]
Hi there,
i’ve installed and setup a Rpi1+ic880a running gateway OS.
The gateway is in a private network (192.168.1/255).
I’ve configured gateway bridge to report to the network server using tcp://serverip:1883.
sudo monit summary is all ok.
I’ve added the gateway on the chirpstack server by copying/pasting ID as it appears in config file
(btw, i’m trying to mimic a working setup where only gateway id changes)
Gateway is never seen.
from ssh terminal i can ping server ip from gw but telnet on port 1883 doesn t work (doen t wok too from a machine in the same LAN)
nmap on server for this port says
PORT STATE SERVICE
1883/tcp filtered mqtt
is there something i’m doing wrong?
Thx by advance.
S.
