Sometime, disconnect between Esp32 and gateway and server ChirpStack
Hi every one,
Problem:
I have problem about ESP32+Lora SX1276 connect with gateway and connect with server ChirpStack by writing firmware send uplink every 1 min. After that, ESP32 +Lora SX1276 not sending uplink then i add watchdog firmware for reset. The result sending uplink again.
Question:
I need to know why ESP32+Lora SX1276 stop sending uplink??
This action, i cannot prove, please help me to solve.
Hello
What kit are you using?
What libraries for your firmware?
I see you opened a thread on the esp32 forum which is a better place to get help unless one knows and has used the same kit and libraries here. They will be interested to know the exact kit and libraries to be able point you in the right direction.
The firmware library forum would be the next place to get help.
Dear Sir,
         I use ESP32-WROOM-32E + Lora sx1276 SEMTECH, and send data to Chirpstack and using the gateway by setting 923MHz Lora end node module.
        The library use "lmic.h", and can see the firmware for send data uplink and downlink.
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
#include <esp_task_wdt.h>
//15 seconds WDT
#define WDT_TIMEOUT 900
// Relay
int value[3] = {};
char tmp[2];
int arr_relaypin[] = {0, 13, 25, 26, 33};//k1,k3,k2,k4
int arr_size = 4;
// LoRaWan
static const u1_t PROGMEM APPEUI[8]={ xxxxx };
void os_getArtEui (u1_t* buf) { memcpy_P(buf, APPEUI, 8);}
static const u1_t PROGMEM DEVEUI[8]={ xxxxx};
void os_getDevEui (u1_t* buf) { memcpy_P(buf, DEVEUI, 8);}
static const u1_t PROGMEM APPKEY[16] = { xxxxx };
void os_getDevKey (u1_t* buf) { memcpy_P(buf, APPKEY, 16);}
static uint8_t mydata[] = “00”;
static osjob_t sendjob;
// Schedule TX every this many seconds (might become longer due to duty cycle limitations).
const unsigned TX_INTERVAL = 60;
// Pin mapping
const lmic_pinmap lmic_pins = {
.nss = 18,
.rxtx = LMIC_UNUSED_PIN,
.rst = 14,
.dio = {2, 4, LMIC_UNUSED_PIN},
void printHex2(unsigned v) {
v &= 0xff;
if (v < 16)
Serial.print(‘0’);
Serial.print(v, HEX);
void onEvent (ev_t ev) {
Serial.print(os_getTime());
Serial.print(": ");
switch(ev) {
case EV_SCAN_TIMEOUT:
Serial.println(F(“EV_SCAN_TIMEOUT”));
break;
case EV_BEACON_FOUND:
Serial.println(F(“EV_BEACON_FOUND”));
break;
case EV_BEACON_MISSED:
Serial.println(F(“EV_BEACON_MISSED”));
break;
case EV_BEACON_TRACKED:
Serial.println(F(“EV_BEACON_TRACKED”));
break;
case EV_JOINING:
Serial.println(F(“EV_JOINING”));
break;
case EV_JOINED:
Serial.println(F(“EV_JOINED”));
u4_t netid = 0;
devaddr_t devaddr = 0;
u1_t nwkKey[16];
u1_t artKey[16];
LMIC_getSessionKeys(&netid, &devaddr, nwkKey, artKey);
Serial.print("netid: ");
Serial.println(netid, DEC);
Serial.print(“devaddr: “);
Serial.println(devaddr, HEX);
Serial.print(“AppSKey: “);
for (size_t i=0; i<sizeof(artKey); ++i) {
if (i != 0)
Serial.print(”-”);
printHex2(artKey[i]);
Serial.println(””);
Serial.print(“NwkSKey: “);
for (size_t i=0; i<sizeof(nwkKey); ++i) {
if (i != 0)
Serial.print(”-”);
printHex2(nwkKey[i]);
Serial.println();
LMIC_setLinkCheckMode(0);
break;
    case EV_JOIN_FAILED:
        Serial.println(F("EV_JOIN_FAILED"));
        break;
    case EV_REJOIN_FAILED:
        Serial.println(F("EV_REJOIN_FAILED"));
        break;
    case EV_TXCOMPLETE:
        Serial.println(F("EV_TXCOMPLETE (includes waiting for RX windows)"));
        if (LMIC.txrxFlags & TXRX_ACK)
          Serial.println(F("Received ack"));
        if (LMIC.dataLen) {
          Serial.print(F("Data Received: "));
          String dpayload = "";
          char temp[3];
          for(uint8_t i=0;i<LMIC.dataLen;i++)
            // Serial.println(i);
            Serial.print(LMIC.frame[LMIC.dataBeg + i], HEX);
            // sprintf(temp, "%02x", LMIC.frame[LMIC.dataBeg + i]);
            sprintf(temp ,"%x", LMIC.frame[LMIC.dataBeg + i]);
            dpayload = String(dpayload) + String(temp);
          Serial.println(dpayload);
          Serial.println();
          if(dpayload != ""){
            pinMode(arr_relaypin[1], OUTPUT);
            pinMode(arr_relaypin[2], OUTPUT);
            pinMode(arr_relaypin[3], OUTPUT);
            pinMode(arr_relaypin[4], OUTPUT);
            dpayload = dpayload.substring(0, 12);
            if (dpayload.length() == 12) {
              String cmd_status = String(dpayload.substring(1, 2)) + String(dpayload.substring(3, 4));
              String cmd_pin = dpayload.substring(5, 6) + dpayload.substring(7, 8);
              String cmd_time = dpayload.substring(9, 10) + dpayload.substring(11, 12);
              int pin = cmd_pin.toInt();
              long timedelay = cmd_time.toInt() * 1000* 60 ;
              if(cmd_status =="01"){
                for(int i = 1; i <= arr_size; i++){
                  Serial.print(String(i) + ". Pin "+String(arr_relaypin[i])+ " Status: ");
                  Serial.println(digitalRead(arr_relaypin[i]));
                  sprintf(tmp,"%02d",digitalRead(arr_relaypin[i]));
              }else if(cmd_status =="02"){
                if(cmd_pin=="99"){
                  Serial.println("Payload: " + dpayload);
                  Serial.println("Relay No: BOTH");
                  Serial.println("Turn On...");
                  for(int i = 1; i<= arr_size; i++){
                    digitalWrite(arr_relaypin[i], HIGH);
                  Serial.print("Delay: ");
                  Serial.print(timedelay);
                  Serial.println(" ms");
                  delay( timedelay );
                    digitalWrite(arr_relaypin[i], LOW);
                  Serial.println("Turn Off...");
                }else{
                  Serial.print("Relay No: ");
                  Serial.println(pin);
                  Serial.print("Pin: ");
                  Serial.println(arr_relaypin[pin]);
                  digitalWrite(arr_relaypin[pin], HIGH);
                  delay( timedelay );
                  digitalWrite(arr_relaypin[pin], LOW);
            }else{
              Serial.println("!! Package Lost : Payload Error !!");
              Serial.print("Payload: ");
          Serial.println();
        esp_task_wdt_reset();
        os_setTimedCallback(&sendjob, os_getTime()+sec2osticks(TX_INTERVAL), do_send);
        break;
    case EV_LOST_TSYNC:
        Serial.println(F("EV_LOST_TSYNC"));
        break;
    case EV_RESET:
        Serial.println(F("EV_RESET"));
        break;
    case EV_RXCOMPLETE:
        // data received in ping slot
        Serial.println(F("EV_RXCOMPLETE"));
        break;
    case EV_LINK_DEAD:
        Serial.println(F("EV_LINK_DEAD"));
        break;
    case EV_LINK_ALIVE:
        Serial.println(F("EV_LINK_ALIVE"));
        break;
    || This event is defined but not used in the code. No
    || point in wasting codespace on it.
    || case EV_SCAN_FOUND:
    ||    Serial.println(F("EV_SCAN_FOUND"));
    ||    break;
    case EV_TXSTART:
        Serial.println(F("EV_TXSTART"));
        break;
    case EV_TXCANCELED:
        Serial.println(F("EV_TXCANCELED"));
        break;
    case EV_RXSTART:
        /* do not print anything -- it wrecks timing */
        break;
    case EV_JOIN_TXCOMPLETE:
        Serial.println(F("EV_JOIN_TXCOMPLETE: no JoinAccept"));
        break;
    default:
        Serial.print(F("Unknown event: "));
        Serial.println((unsigned) ev);
        break;
void do_send(osjob_t* j){
// Check if there is not a current TX/RX job running
if (LMIC.opmode & OP_TXRXPEND) {
Serial.println(F(“OP_TXRXPEND, not sending”));
} else {
// Prepare upstream data transmission at the next possible time.
LMIC_setTxData2(22, mydata, sizeof(mydata)+4, 0);
Serial.println(F(“Packet queued”));
void setup() {
Serial.begin(115200);
Serial.println(F(“Starting”));
#ifdef VCC_ENABLE
// For Pinoccio Scout boards
pinMode(VCC_ENABLE, OUTPUT);
digitalWrite(VCC_ENABLE, HIGH);
delay(1000);
#endif
Serial.println("Configuring WDT...");
esp_task_wdt_init(WDT_TIMEOUT, true); //enable panic so ESP32 restarts
esp_task_wdt_add(NULL); //add current thread to WDT watch
// LMIC init
os_init();
// Reset the MAC state. Session and pending data transfers will be discarded.
LMIC_reset();
LMIC_setDrTxpow(DR_SF9,14);
LMIC_setClockError(MAX_CLOCK_ERROR * 10 / 100);
// Start job
do_send(&sendjob);
int i = 0;
int last = millis();
void loop() {
os_runloop_once();
You call do_send in setup, this is only run once on boot.
You may want to read how to use the loop section in arduino.
Can you recommend about web for read concern how to use the loop section in Arduino??
