I was able to configure ssl certification in my docker environment for mqtt integration following this guide
https://www.chirpstack.io/docs/guides/mosquitto-tls-configuration.html
My question is if there is a way to generate the cert client for this mqtt integration outside the ui?
I’m using traefik for ssl endpoint with letsencrypt for the ui and the self signed certificates for the mqtt integration but I want to know if is it possible to do everything with traefik and letscrypt as ssl/tls provider
Regards
