Thank you so much @chopmann for all your support we appreciate it!!
And yes we used his image it was possible to communicate with Chirpstack, although the message that the device was not found with that name continues to appear, the data is correctly transmitted to the Orion Context Broker.
At the beginning of using the IoTA there was an error, and looking on the internet we found that it was related to the transported bytes, so I configured my SODAQ device to send few bytes and with this, the problem was solved, after that, change the size again of the frame to send the bytes that it sent in the beginning … so I think it was some kind of bug.
iot-agent_1 | {“timestamp”:“2021-03-26T18:42:05.752Z”, “level”:“info”, “message”:“IOTA provisioned devices:”}
iot-agent_1 | {“timestamp”:“2021-03-26T18:42:05.752Z”, “level”:“info”,“message”: “Decoding CaynneLPP message:B2cA+AhnAOQEaCI=”}
iot-agent_1 | {“timestamp”:“2021-03-26T18:42:05.753Z”, “level”:“error”, “message”:“Could not cast message to NGSI”, “dev_eui”: “0004a30b002212f0”, “dev_id”: “SODAQExpLoRer-1”}
Now it works:
iot-agent_1 | {“timestamp”:“2021-03-26T18:42:36.131Z”, “level”: “info”, “message”: “IOTA provisioned devices:”}
iot-agent_1 | {“timestamp”:“2021-03-26T18:42:36.132Z”, “level”: “info”, “message”: “Decoding CaynneLPP message:AWcA+A==”}
iot-agent_1 | time=2021-03-26T18:42:36.134Z | lvl=DEBUG | corr=n/a | trans=n/a | op=IoTAgentNGSI.NGSIService | srv=infotec | subsrv=/prueba | msg=executeWithDeviceInfo entityName sodaqexplorer-N-001 type LoraDevice apikey attributes [{“name”:“temperature_1”, “type”:“Number”, “value”:24.8}] deviceInformation {“lazy”:[],“active”:[{“object_id”:“rh1”,“name”:“relative_humidity_1”,“type”:“Number”},{“object_id”:“t1”,“name”:“temperature_1”,“type”:“Number”},{“object_id”:“t2”,“name”:“temperature_2”,“type”:“Number”}],“commands”:[],“staticAttributes”:[],“subscriptions”:[],"_id": “605e27a8910a3100076fae6d”, “creationDate”: “2021-03-26T18:27:52.516Z”, “id”:“SODAQExpLoRer-1”,“type”:“LoraDevice”,“name”: “sodaqexplorer-N-001”, “service”: “infotec”, “subservice”: “/prueba”, “internalId”: null, “internalAttributes”: {“lorawan”: {“application_server”:{“host”:“180.179.214.165”, “username”:“user”, “password”:“pwd”,
“provider”: “chirpstack.io”}, “dev_eui”: “0004a30b002212f0”, “app_eui”: “0000000000000000”, “application_id”: “1”, “application_key”: “3ae8feaceaede897d3b38857d60fe244”, “data_model”: “cayennelpp”}}, “transport”:“MQTT”}
