I am trying to implement the mTLS over MQTT with TLS version 1.1 and TLS engine in the Chirpstack application.
For example, for the mosquito client, I have started with the following parameters:
mosquitto_sub --cafile /tmp/certificates/authority.pem --tls-engine dbus --keyform engine --key /tmp/dbus-device-key.pem --cert /tmp/certificates/device.pem -h -p 10883 --tls-version tlsv1.1 -v -t ‘test/topic’
Now I want to securely communicate with the Chirpstack network server, application server and gateway bridge using MQTT.
In the mosquitto.conf
file, there are a few parameters viz #certfile
and #keyfile
and corresponding parameters are mentioned in the Chirpstack toml file as ca_cert
, tls_cert
and tls_key
But I also want to use --tls-engine
, --keyform
, and, --tls-version
. These are not available in the default toml file.
Are these flags supported or not? If these are supported, what are the corresponding names of the parameters that can be used in the toml file?
