kamalch
November 14, 2020, 11:23am
1
Hello
I want to use class-c.
I checked the check box as shown.
But now the device is still class-A.
why?
Because after filling in the Payload and port sections, the message is still queued and waiting for the Uplink to occur; it should be sent immediately.
Is it true?
eugenev
November 14, 2020, 11:33am
2
device must operate in class C as its own. simply setting this checkbox does nothing with endnode.
kamalch
November 14, 2020, 11:37am
3
I set the End-Device in class-C. but I can’t set class-C in server.
eugenev
November 14, 2020, 11:38am
4
after changes, you need to reactivate device.
kamalch
November 14, 2020, 11:39am
5
May you please explain more?
eugenev
November 14, 2020, 11:41am
6
application->device->activation->(re)activate device
kamalch
November 14, 2020, 12:12pm
7
Thanks a lot.
Queue problem solved. but after downlink, I can’t see any downlink in “Device Data”.
Is it normal?
eugenev
November 14, 2020, 12:28pm
8
kamalch:
Is it normal?
it depends on gateway packet forwarder which you’re using
kamalch
November 14, 2020, 12:37pm
9
In class-A it was ok!
I use RisingHF outdoor gateway (SEMTECH UDP Packet forwarder)
