Howto update a gateway os with the file .swu.
how to download the swu file to the sd card of a raspberry.
tanks
use curl or wget to download the file update file to the gateway.
for example on an rpi3 i used to make a directory in the home folder called updates when there was an update i’d hop into that directory by
cd updates
then download the update like so
wget https://artifacts.chirpstack.io/downloads/chirpstack-gateway-os/raspberrypi/raspberrypi3/4.1.1/chirpstack-gateway-os-base-update-raspberrypi3-20230322153826.swu
then to run the update…
sudo software-update chirpstack-gateway-os-base-update-raspberrypi3-20230322153826.swu
or if you stuck it somewhere else…
sudo software /path/to/update/chirpstack-gateway-os-base-update-raspberrypi3-20230322153826.swu
https://www.chirpstack.io/docs/chirpstack-gateway-os/use/software-update.html
Thank you very much for the reply .
I have already been able to update the gateway.
