I installed all chirpstack components on a single AWS VM server. All components are to be running. Tektelic micro gateway is also on the network and I see the gateway with UI
I have defined the following device profile for kona home sensor
kona home sensor is not sending JOIN. I made sure that devEUI for devices/sensors is entered corrected. What else do I need todo?
