Hello, I’m recently new in chirpstack and I want to know if there is a way to connect to the chirpstack database via postgres SQL in windows.
I’m using Docker in order to install and manage the servers. Also I’m using Kitematic to see the configuration in a better way.
Using Kitematic I try to set a published IP:PORT in order to connect, but it causes a crash in the server and stop working properly, so I’m a bit lost in order to what to do.
