Is there any reference packet for the time, timeSinceGpsEpoch and timestamp values?
How to get proper data values at loraserver for achieving geolocation?
If you have any reference packet format as per kerlink gateway’s packet forwarder or any other please share the same.
Hello @Yash_pahwa
I’m having the exact same issue, how did you solved it? I read that in your update on May 2019 you got the time and timeSinceGpsEpoch values. How did you do it?
The reason is that the HAL uses binary u-blox specific messages to retrieve the monotonic “GPS epoch” time. Technically you could use other GNSS modules, but you would need to extend the HAL library for getting the GPS epoch time.
