TLS handshake error, even after clearing the docker cache
I am connecting to the appserver via https://localhost:8080 (note the s )
I get the dreaded TLS handshake error. I’m running the standard docker image, which I assume is (based on the Dockerfile) building the TLS certificates. Is that an incorrect assumption? I don’t think so.
At Orne’s suggestion, I cleared all of the docker cache, removing all containers, killed all dangling containers and removed them, then tried again. I am still getting this error, which happens as soon as I try to create a network server
appserver_1 | 2017/12/01 17:08:27 http: TLS handshake error from 127.0.0.1:51476: tls: first record does not look like a TLS handshake
appserver_1 | time=“2017-12-01T17:08:27Z” level=info msg=“transport: http2Client.notifyError got notified that the client transport was broken read tcp 127.0.0.1:51476->127.0.0.1:8080: read: connection reset by peer.”
The web browser reports
Error: rpc error code = Unavailable desc = transport is closing (code: 2)
Suggestions?
Did you try the docker-compose.yml file mentioned at https://docs.loraserver.io/install/docker/
version: "2"
services:
  loraserver:
    image: loraserver/loraserver
    environment:
      - DB_AUTOMIGRATE=true
      - LOG_NODE_FRAMES=true
      - NET_ID=010203
      - BAND=EU_863_870
      - REDIS_URL=redis://redis:6379
      - GW_MQTT_SERVER=tcp://mosquitto:1883
      - GW_SERVER_JWT_SECRET=verysecret
      - POSTGRES_DSN=postgres://loraserver_ns:loraserver_ns@postgresql_ns/loraserver_ns?sslmode=disable
      - JS_SERVER=http://appserver:8003
  appserver:
    image: loraserver/lora-app-server
    ports:
      - 8080:8080
    environment:
      - POSTGRES_DSN=postgres://loraserver_as:loraserver_as@postgresql_as/loraserver_as?sslmode=disable
      - MQTT_SERVER=tcp://mosquitto:1883
      - JWT_SECRET=verysecret
      - HTTP_TLS_CERT=/etc/lora-app-server/certs/http.pem
      - HTTP_TLS_KEY=/etc/lora-app-server/certs/http-key.pem
      - AS_PUBLIC_SERVER=appserver:8001
  gatewaybridge:
    ports:
      - 1700:1700/udp
    image: loraserver/lora-gateway-bridge
    environment:
  postgresql_ns:
    image: postgres:9.6-alpine
    ports:
      - 5432
    environment:
      - POSTGRES_PASSWORD=loraserver_ns
      - POSTGRES_USER=loraserver_ns
      - POSTGRES_DB=loraserver_ns
  postgresql_as:
    ports:
      - 5432
    environment:
      - POSTGRES_PASSWORD=loraserver_as
      - POSTGRES_USER=loraserver_as
      - POSTGRES_DB=loraserver_as
  redis:
    ports:
      - 6379
    image: redis:4-alpine
  mosquitto:
    ports:
      - 1883
    image: eclipse-mosquitto
Would you be able to try that (put it in a directory and then run docker-compose up)? I tried it at my side without any issues. Please note that you should clear your browser cache (that was my issue). The LoRa App Server docker image contains a self-signed certificate, which is fine for testing. For production you should replace this of course :slight_smile:
I downloaded the yml file you mentioned and did a docker-compose up. After that, started the browser, logged in (admin), then tried to add a network server (localhost:8080). I got the same error as described below.
BTW, here is my yml file. Note that I am running the gateway on another machine. And yes, I did clear the browser cache too …
After running docker-compose up, then starting Firefox, logging in as admin, and trying to create a network server (localhost:8080), I get this error:
Error rpc error: code = Unavailable desc = transport is closing (code: 2)
in the browser and
appserver_1 | 2017/12/01 19:17:38 http: TLS handshake error from 127.0.0.1:58250: tls: first record does not look like a TLS handshake
appserver_1 | time=“2017-12-01T19:17:38Z” level=info msg="transport: http2Client.notifyError got notified that the client transport was broken read tcp 127.0.0.1:58250->127.0.0.1:8080: read: connection reset by peer."
Here is the yml file (passwords changed)
version: “2”
services:
loraserver:
environment:
- NET_ID=010203
- BAND=US_902_928
- GW_MQTT_USERNAME=user
- GW_MQTT_PASSWORD=password
- GW_CREATE_ON_STATS=true
depends_on:
- postgresql_ns
- redis
- mosquitto
appserver:
ports:
- 8080:8080
environment:
- MQTT_USERNAME=user
- MQTT_PASSWORD=password
depends_on:
- postgresql_as
- mosquitto
- redis
- loraserver
postgresql_ns:
ports:
- 5432
environment:
postgresql_as:
ports:
- 5432
environment:
redis:
ports:
- 6379
mosquitto:
image: iq/mosquitto
ports:
- “1883:1883”
- “8883:8883”
- “9001:9001”
environment:
- MQTT_LOGIN_USERNAME=user
- MQTT_LOGIN_PASSWORD=password
By default the network-server (LoRa Server) is listening on port 8000. This is not the same port as the LoRa App Server UI and API interface.
Slaps head at stupidity. Okay, adding localhost:8000 (rather than localhost:8080) as a network server introduces a different error (using the stock yml file you suggested): Which service is failing to connect on port 8000?
appserver_1 | time=“2017-12-01T21:55:39Z” level=info msg="grpc: addrConn.resetTransport failed to create client transport: connection error: desc = “transport: Error while dialing dial tcp 127.0.0.1:8000: getsockopt: connection refused”; Reconnecting to {localhost:8000 }"
and the website reports
Error context deadline exceeded (code: 2)
I apologize for asking so many questions
Try loraserver:8000 so it matches the container name :slight_smile:
That worked, thank you!
Now on to the next issue :slight_smile:
