To send MAC commands
I am trying to send MAC Commands on Fport0, but I am not able to do. How can I do this? Please any help is appreciated, I have to urgently complete the task.
In what usecase you want to send a MAC command?
Thank you for replying.
Actually I am working on LoRa relay project.
Basically the usecase is that I want to set a single frequency channel for communication since LoRA has frequency hopping. So I wanted to prevent that, set a single frequency channel which can be done using MAC command right?
Is there any way that I can achieve this?
You can’t manually send MAC commands.
Which software do you use for the end-device?
Hey,
So actually we are using Dragino RS485-LB sensor node which is actually acting as the end device. So to basically control all downlink and uplink messages we are using chirpstack only. To control the end node we are doing using AT commands on Serial port utility.
I think if the command 6.8 is supported from your device you are ok. But use it only for testing.
Yeah we are basically conducting research and trying to test the network. So we only need to know how to access the MAC commands to test them. But for that are there methods through which we achieve this?
Build a node so you can send in one frequency. It’s not difficult. The cheapest board will make this job.
Since it’s for testing, you can scrap Dragino for the test. Or buy one which supports one channel. Use it only for testing.
Have you tried setting enabled_uplink_channels? chirpstack/chirpstack/configuration/region_us915_0.toml at master · chirpstack/chirpstack · GitHub
I have not tested this, but it might also work for EU868 to limit the amount of uplink channels.
