Hello, Im trying to connect the gateway bridge, network server and app server in diferent hosts, but Im still confused after reading the documentation, I was able to add the network server successfully on the app web interface.
but Im still not sure what to set on these sections of the file
Join-server settings.
[join_server]
This API is provided by ChirpStack Application Server.
server=“http://localhost:8003”
server=“http://192.168.0.10:8003”
does this section is important for something ? because I think the bind is already done here .
Network-server API
bind=“0.0.0.0:8000”
I guess its saying the app server can bind through any ip, I guess.
and with the app setting theres also two sections like the network server
Settings for the “internal api”
# This is the API used by ChirpStack Network Server to communicate with ChirpStack Application Server
bind="0.0.0.0:8001"
and
Join-server configuration.
bind=“192.168.0.12:8003”
Im just kinda confused because there are two configuration and I dont see the difference between both of them, also they use different ports, if anybody can clear me this out I would appreciate it.
Thanks.
