I’m trying to use the HTTP integration and the chirpstack API to implement the Clock synchronization
I’m using python with flask to decode the payload and then I use this example to enque the response.
The problem I have with this method is that it doesn’t transmit the response in the RX window after the uplink but only when the next uplink occurs. I think there is not enough time to process the data after the uplink.
I also tried to modify the chirpstack-network-server.toml (I use the docker of chirpstack) and change the rx1_delay but it doesn’t seems to work, the delay is always 1sec.
Is there a good way to do that?
Thank’s
