I have solved the above issue. Now everything is fine but when i subscribe to mqtt topic (mosquitto_sub -h 127.0.0.1 -t application/+/node/00000000220003ba/rx) am getting the data but it is not decrypted.
I can see something like below messages in lora-app-server logs
INFO[1644] handler/mqtt: publishing data-up payload topic=“application/8/node/00000000220003ba/rx”
INFO[1534] data-down item requested by network-server, but queue is empty dev_eui=00000000220003ba
Are sure you sure the data is encrypted and not simply encoded?
Have you tried running the data through a base 64 decoder?
I like using this one:
I believe this is normal - it indicates there are no pending messages waiting to be sent to the node.
When you send a message to a node via MQTT - you should see something like:
