Hello all!
I have a new SenseCAP LoRaWAN Outdoor Gateway (US915, SX1301) I want to be able to use with the Wio-E5 mini sensors from Seeed Studio. I have previously used ChirpStack with another gateway, but I am struggling to connect my sensors to ChirpStack and SenseCAP outdoor gateway US915. I can access the LoRa server built into the gateway. I can also see the gateway active on ChirpStack API (login with port 8080). The gateway came with its EUI and KEY. I used the EUI to create the gateway profile. I am having problems connecting the Wio-E5 mini sensors in ChirpStack. All the Join requests fail or don’t appear. I have 2 profiles for two sensors under the Applications panel. Has anyone else done anything similar?
Is the SenseCAP Outdoor gateway only compatible to work with the SenseCAP S210X Sensors only?
I am following the main steps from this guide:
https://sensecap-docs.seeed.cc/pdf/Guide-for-SenseCAP-Adaption-to-3rd-Party-Gateways-Servers-V1.2.pdf
Thank you!
