I made it to the bottom of the getting started guide and moved across to the “First gateway” guide, and I’m running into a little confusion. The first part description doesn’t tell me where these configuration keys live:
Modify the packet-forwarder of your gateway so that it will send its data to the LoRa Gateway Bridge. You will need to change the following configuration keys:
server_address
to the IP address / hostname of the LoRa Gateway Bridgeserv_port_up
to1700
(the default port that LoRa Gateway Bridge is using)serv_port_down
to1700
(same)
Where do I find these keys to modify them? I presume there’s a configuration file, but the link above links to a github. Do I have to recompile the packet forwarder and hardcode the server address and ports? I think this software was installed as part of the getting started guide. The scripts referenced in the “packet_forwarder” page do not appear to exist on my system.
Did I miss a step?
