Here my logs from base-station:
JSON up: {“rxpk”:[{“tmst”:176402116,“chan”:6,“rfch”:1,“freq”:869.100000,“stat”:1,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“lsnr”:10.0,“rssi”:-48,“size”:45,“data”:“QBVeHwGBAAACAjw4gerXAgi/ScVhVmrTsuiBGTUpYmHkxjYZjaJNSGy59dUo”}]}
INFO: [up] PUSH_ACK received in 13 ms
INFO: [down] PULL_RESP received - token[102:110] )
JSON down: {“txpk”:{“imme”:false,“tmst”:177402116,“freq”:869.1,“rfch”:0,“powe”:14,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“ipol”:true,“size”:20,“data”:“YBVeHwGIAAACHgEDUQMAARRfla4=”,“brd”:0,“ant”:0}}
INFO: tx_start_delay=1495 (1495.500000) - (1497, bw_delay=1.500000, notch_delay=0.000000)
INFO: Received pkt from mote: 011F5E15 (fcnt=0)
JSON up: {“rxpk”:[{“tmst”:178721012,“chan”:5,“rfch”:1,“freq”:868.900000,“stat”:1,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“lsnr”:-19.0,“rssi”:-111,“size”:20,“data”:“YBVeHwGIAAACHgEDUQMAARRfla4=”}]}
INFO: [up] PUSH_ACK received in 14 ms
first rx is the message with LinkCheckReq
also maybe you know why tx message is the same with last rx?
PS: when i`m sending pure downlinks - there no repeating tx
