I have a UG65 gateway (on firmware 60.0.0.42-r5) and have been trying to get it to send data to my MQTT broker as JSON. The application data does show in JSON, but the gateway topics (e.g gateway/id/event/stats) show up in binary as shown in the snippet below.
ߴ��08j����z ��a(�
When I look at the web dashboard everything seems fine as I can see the gateway is online and the lorawan frames coming in.
I have modified the configuration files from GitHub - chirpstack/chirpstack-docker: Setup ChirpStack using Docker Compose to include json=true.
chirpstack.toml
# Logging.
[logging]
# Log level.
level="info"
# PostgreSQL configuration.
[postgresql]
# PostgreSQL DSN.
# SSL mode options:
# * disable - no SSL
dsn="postgres://chirpstack:chirpstack@$POSTGRESQL_HOST/chirpstack?sslmode=disable"
# Max open connections.
# PostgreSQL connection pool.
max_open_connections=10
# Min idle connections.
min_idle_connections=0
# Redis configuration.
[redis]
servers=[
"redis://$REDIS_HOST/",
# TLS enabled.
tls_enabled=false
# Redis Cluster.
# instance.
cluster=false
[network]
net_id="000000"
# Enabled regions.
enabled_regions=[
# "as923",
# "as923_2",
# "as923_3",
# "as923_4",
# "au915_0",
# "cn470_10",
# "cn779",
# "eu433",
"eu868",
# "in865",
# "ism2400",
# "kr920",
# "ru864",
# "us915_0",
# "us915_1",
[api]
bind="0.0.0.0:8080"
# Secret.
# openssl rand -base64 32
secret="you-must-replace-this"
[integration]
enabled=["mqtt"]
[integration.mqtt]
server="tcp://$MQTT_BROKER_HOST:1883/"
json=true
username="user"
password="password"
client_id="chirpchirp"
